Drag Racing Tech
Bogarts / Alumastars vs Prostars (ET Difference)
Old 11-03-2011, 04:06 PM
02sleeperz28's Avatar
Originally Posted by chrs1313
not sure on the gearing of that trans to mate with that stall
but the 4L60E trans gearing, with 4.10s out back on 28" tall MT drag radials, with off the shelf yank ss4000 has put me to a 1.28 60ft at 3000 raceweight...+350ft da 520rwhp 440rwtq...
Also i tried the 1" spohn rear sway bar and it was junk, pony up and get a rear drag bar ~$400 night and day difference...
Chris
Rear sway bar swap made that much of a difference for you? Can you elaborate more? Why did you change from the Spohn bar to a $400 one?
Old 11-03-2011, 06:12 PM
The Guy in MY 99TA's Avatar
bain... just un *** some of that big money you've made over all these years!!!
so whats the specs on the camshaft? There may be more out there with a different camshaft profile.
Old 11-03-2011, 06:53 PM
lemons12's Avatar
I would get that 60 straightened out before anything. You have another .1 or more in it.. which would be .2 or more through the traps.
Old 11-03-2011, 07:02 PM
Chris1313!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!
Old 11-03-2011, 08:38 PM
BAIN's Avatar
Chris
The transmission has a 2.84 first gear. What bar did you go with?
Old 11-03-2011, 09:10 PM
BAIN's Avatar
Josh seriously? Does your car even run? You have been working on it for what 9 years?
Old 11-04-2011, 06:28 AM
as a matter of a fact I have been working on it!!!!
im no big money pimp like you though! lol
im cerealous though, i've been seeing some cars make a big difference with a good gear here lately. as a matter of a fact I saw a stock bottom end car go 10.4s 3 weeks ago and go 9.9xs last weekend w/ just a gear change. but it is an ls3 bottom end
Old 11-04-2011, 09:42 AM
chrs1313's Avatar
The 1" spohn sway is maybe good for a SI car but once you start making more power the body want to twist and flex in the rear unloading the one tire, with the preload from the drag bar and it being a ton stronger the car leaves like an arrow, both tires firmly planted in the rear with both front even in the air...
yeah I though the 4l60e was like a 3.05 ish...so a slightly higher stall might help you to overcome that smaller gear...
Spohn drag bar bolt in...there are alot of options now, I believe the UMI has better provision for shock clearance...mine rubs some on either launches or turns...
Old 11-04-2011, 10:41 PM
Thanks Chris!
Old 11-05-2011, 09:20 PM
BOLO's Avatar
FYI, the 4L60E has 3.06:1 first gear.
Old 11-15-2011, 07:38 PM
BAIN's Avatar
Originally Posted by studderin
if you dont have 465s with the 28s the cars gona be ever slower with 30's
not to be rude but you have a lot of room in thouse 60's. get the car to go low 1.4s and you'll move up a few spots. Get 465s. stay with the 28x10.5s or try 275 radials if you have good shocks.
Not sure I could make it through the 1/4 with 4.56's on 28's with this loose of a converter. I did pick up some rear double adjustable Afcos though.
Old 11-17-2011, 03:53 PM
  #32
chevelledave's Avatar
did the package arrive ???
Old 11-17-2011, 09:49 PM
  #33
BAIN's Avatar
Yes UPS delivered them about 8:30 last night
Quick Reply: Bogarts / Alumastars vs Prostars (ET Difference)
