Build me a e85 fuel system!
pix, part numbers and all help is greatly appreciated.
thanks
edit" lt1 tank with lt1 sending unit. Need pumps for this?
what lines from the filter forward?
It contains teflon lines & E85 specific filter, plus regulator, rails & all fittings.
I can custom build a kit specifically for your needs, including injectors if desired.
Please call if you want to discuss in more detail.
When building your system keep in mind the corrosive nature of E85 will require parts that will prevent damage over time. Also the system will need to be capable of pushing roughly 30% more volume for the E85 as opposed to gasoline fuel for the same hp rating.
But you have one guy saying stock lines ok, stock tank ok, replace fuel pump, replace injectors etc etc.
Just because someone has never "seen" a problem doesn't mean it's not a problem.
Stainless/plastic tanks and lines, teflon lines, E 85 compatable parts (fuel pumps-injectors etc) are used for a reason.
Truth is getting a stock style E85 compatable tank is a royal pain in the *** and can be a huge expense, especially when you want to use a tank sump and external fuel pump and many people just say **** it.
Stock lines are ok? On what exactly? how much volume can u push thru that small diameter line on a big HP application keeping in mind you need that 30% more volume.
1000 ways to skin a cat I guess.
If we ever get E85 around here I may consider it myself.
need to order parts quickly.
Im going to run dual pumps right now for the street without the turbo. Just to tune it and test the new setup. I can run the lines to a corvette filter/regulator then need a line from the filter forward to the line? A return line I need as well with a regulator
pix and part numbers please.
http://www.dynotuneusa.com/DynotuneUSA/Photos.html
