Whats needed to get a m6 02 firehawk into the 12.80 range
Longtubes, ORY, Catback (not flowmaster), lid, tune, and drag radials should get an 02 into the 12's some cars can even break 12's with just the drag radials but the other mods would ensure you get there
LS1Tech Premium Sponsor
Driver and good altitude can get you there...
__________________
![](https://ls1tech.com/forums/signaturepics/sigpic211066_2.gif)
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
what he said ^ but to expand a bit good "density altitude" learn what it is and only plan on getting great times when da conditions are favorable like well below sea level, in my area over the next few months it shouldnt be hard to find 1,000 to 1500 below sea level but anything below sea level should get you in spitting distance- several documented cases of stock m6 cars getting into the 12's
When I went to the Sacramento raceway a few years back when my 2000 Trans Am had nothing but a magnaflow cat back I was pulling 13.3's all night long @ 111mph. My limiting factor that kept me out of the 12's was my stock tires. I tried a ton of different launch techniques that night, and the best I could pull were 2.2 and 2.3 60ft's. The car would spin through first gear and partially in the beginning of second gear everytime. Didn't matter if I feathered the gas, rolled out a few feet then laid into it, or revved it up high and dumped the clutch, it was the same story. Once I got on the gas in first the tires would just start spinning. If I had a good set of tires I would have cut a few high 12's. It was like trying to launch on ice or an oil slick. If those tires could have just hooked, even rolling a few feet off the line to get going and then softly laying into it gradually into full throttle it would have been easy.
OP, please excuse my response as it may seem like a smart response. What kind of times are you currently running, and what setup do you currently have?
__________________
your response was fine Jake. Your in the business of selling parts and didnt jump right to trying to sell him parts but rather mentioned his goals were possible without spending money just by making sure driving technique and going with favorable weather conditions .
Where will you be racing the car ? gives us an ideaof the built in altitude and weather your facing , hopefully your not in Denver lol
I don't have acr yet but I'm looking at several. I want to add mods that I can easily return to stock down the road if I decide to. Is it an advantage to change the air lid if the car comes with the Donaldson Blackwing lid already? Does a gear swap (4.10 or 3.73) help much on a bolt on only car? I would like to do LT's, ORY, good sounding y pipe back exhaust with a factory firehawk look; I'm looking for a deep sound that is not terribly loud. Any good tuners in Cincinnati? Thanks for any input.
__________________
