Drag Racing Tech
Would you expect to drop 1 sec in the 1/4?
Old Sep 12, 2012 | 10:14 AM
senicalj4579's Avatar
Question Would you expect to drop 1 sec in the 1/4?
My car with a raceweight of 3400-3450lbs did 11.9 last year. Car dynoed 326/334.
Car is now at 429/392. A gain of 103rwh and 58rwt.
Now, providing the car can hook and the da is the same, would you expect to drop a full second?
Old Sep 12, 2012 | 12:04 PM
zracer323's Avatar
Running 10.9 with 429hp at 3400 lbs will be tough. It is definitely doable but takes a very optimized setup.
Old Sep 12, 2012 | 02:39 PM
starbucks's Avatar
^^^^^^ what this guy said. ^^^^
Old Sep 12, 2012 | 03:11 PM
thunderstruck507's Avatar
I would not expect to drop that much. Seems to be around the ET point where more HP is needed than than the .10 per 10hp rule. I would hope for some 11.20s though, you might still make 10s but then you can consider it a nice surprise.
Old Sep 12, 2012 | 03:35 PM
subhumanzz's Avatar
not likely. i can see a 11.20 like mentioned above though, good luck.
Old Sep 12, 2012 | 04:25 PM
Villain281H's Avatar
7 Second Club
From: Gainesville, Florida # of drag strips runs: ?!?!?
As mentioned, it could happen but will likely need an optimal setup and air.
Derek
Old Sep 12, 2012 | 07:37 PM
Mike Morris's Avatar
Lose about 100 pounds and you can do it
Old Sep 12, 2012 | 08:14 PM
SPEEDYws6's Avatar
My car consistently went .9-1 second faster on a 150 shot. So I say no.
Old Sep 12, 2012 | 08:35 PM
Jay-P's Avatar
cage time.
Looking forward to see what you will run.
Old Sep 12, 2012 | 08:50 PM
Mighty Whitey's Avatar
It's all in the weight and 60'
With 344hp/346tq @3140RW, I managed a 11.15@120 on a 1.52 60'
Horsepower will only get you so far, weight and 60' will get you the rest.
Old Sep 12, 2012 | 09:06 PM
BOLO's Avatar
Other factors as well, such as suspension, weight transfer, traction etc.
Old Sep 12, 2012 | 09:14 PM
7 Second Club
Originally Posted by Jay-P
cage time.
I'm guessing you meant roll bar. 10.00-11.49 requires a 5-point minimum roll bar, 10.00 /135 mph or better requires a full cage (roof halo and front pillar/down bars)
Not hating, just wanting to clarify.
Derek
Old Sep 12, 2012 | 10:07 PM
Jay-P's Avatar
Derek
ya sorry lol, roll bar time just doesnt have the same ring to it.
Old Sep 12, 2012 | 10:47 PM
Thats why I said 60'. It sums it all up.
you can have any number of the factors you mentioned, but if it all isn't working together to 60' right, it doesn't mean squat.
Old Sep 13, 2012 | 12:58 AM
I got the boot lol
https://ls1tech.com/forums/11-second...l#post16716767
Old Sep 13, 2012 | 04:10 AM
blk/slvr02ss's Avatar
Thats Awesome !!!!!!! You will hit 10's w/ a better 60ft now time for suspension !!!! Bring it down here on T&T u can run 8's w/ out a cage and they wont kick you out !
Old Sep 13, 2012 | 05:36 AM
BAIN's Avatar
With 122mph it has the power to dip into the 10's. I ran 10.8's with 122mph
What is your setup ( suspension, gears, converter, etc..)?
Old Sep 13, 2012 | 09:36 AM
Awesome!
Stock suspension minus front swaybar, 3.73 gears (which are making alot more noise after last night), yank ss3600 and mt drs 275 40 17. Tried 25, 20 and 18 psi. The track just sucked.
Old Sep 13, 2012 | 12:28 PM
BAIN's Avatar
Originally Posted by senicalj4579
Awesome!
So no suspension, 17" drag radials (which means you are on 17" rims), and a somewhat small converter.
My suggestion first is to get a looser converter in the 4000+range and lighter drag rim/tire setup. Then work on the suspension.
Old Sep 13, 2012 | 01:18 PM
Suspension and some 15'' Welds 15x10 & 15x4 and u will be well into the 10's !!!!
