Post pictures of cut shock towers
Looking for someone on here who has cut out the front and rear metal from the shock towers, and if you braced it with bars or not. Had a buddy tell me he seen a picture floating around on here of the front and rear metal removed with tube supports on both sides. Please post up whatever you have. Thanks
Again though, maybe I'm missing something or missunderstanding the idea?
Mike
Race your car!
The part you are talking about is a thinner sheet metal, and you probably would be ok if you only removed those and nothing else.
I would not, however do this to anything other then a track only car... The amount of dirt and debris you will send into the engine bay will have you cleaning it like crazy if you drive on normal roads..... Unless having the engine bay look as ugly as possible is your goal.
