Drag Racing Tech
LS engine with th400 flexplate?
Old Dec 9, 2012 | 07:38 PM
Boosted Firehawk's Avatar
Default LS engine with th400 flexplate?
which one to get for my setup?
part numbers would be great and or links!
hub adapter as well?
thanks
Old Dec 9, 2012 | 08:07 PM
78buturbo's Avatar
http://www.summitracing.com/parts/hup-hp3795 hope this helps you should be ok with the factory flex plate from what I understand. Some one correct me if I'm wrong.
Old Dec 9, 2012 | 08:50 PM
y2k_ta's Avatar
'Bird Director
From: Central Indiana Honors: 4th grade spelling bee contestant
Look up the parts for this offered by Hughes Transmissions.
Old Dec 9, 2012 | 10:29 PM
snyousef's Avatar
LS flexplate but you need to use a spacer like shown above....if you have a flat LS flexplate you need a different spacer that bolts to the crank then you bolt the fp to it but if you have the dished LS fp you can use the one above from hughes, it goes between the the fp and the tc
Old Dec 9, 2012 | 10:33 PM
snyousef's Avatar
Here's a thread about it....
https://ls1tech.com/forums/conversio...uto-trans.html
Old Dec 9, 2012 | 10:55 PM
Prorac1's Avatar
I used a hughes performance HP4004X dished flexplate with the GM spacer. Worked great. Hope this helps. Eric L
Old Dec 10, 2012 | 09:06 AM
Prorac1-= you have part numbers?
I dont have a flexplate right now so any will do. I will need to find a stocker if it works and the whatever adapter for that FP...
Old Dec 10, 2012 | 04:31 PM
Prorac1's Avatar
Yeah, HP4004X. Eric L
Old Dec 10, 2012 | 04:41 PM
so that will work with all ls1 and 5.3L engines to adapt a th400 with out the use of a extra spacer correct?
Old Dec 10, 2012 | 05:10 PM
Beau@SDPC's Avatar
LS1Tech Sponsor
Their are a few different options. Give us a call or PM and we will get you fixed up!
Old Dec 10, 2012 | 07:49 PM
Doug G's Avatar
I did the TCI plate on my LS/TH350 combo....
P/N 399753
SFI rated.
Old Dec 11, 2012 | 12:51 PM
Camaro396's Avatar
P/N 399753
SFI rated.
Same one I went with. And I had a converter from Lenny at Ultimate Converter Concepts which was built for a LS1 engine and th400 trans so I didn't need any spacer or anything.
Old Dec 11, 2012 | 07:20 PM
Prorac1's Avatar
You will have to use the GM spacer with the flexplate. And yes it should work with any LS bolting to a TH trans. Watch out for the early motors with the extended crank. And its SFI approved. IIRC it cost me around $140. Eric L
