Drag Racing Tech
Weight reduction list!!!
Old Nov 3, 2005 | 01:21 PM
  #321
Phoenix H.O.'s Avatar
what about the weight difference between the trans am headlights and the fixed trans am lights like mine. the assebly that i have only weighs about 5 punds all together. how much does the stock motorized setup weigh?
Old Nov 13, 2005 | 07:25 PM
  #322
CW00BlackTA's Avatar
Just weighed Trans Am power leather seats with bathroom scale--didn't see specifics for these on the list.
Rear seats and seat belts (including all hardware) - 33 lbs.
Front seats (driver is 4 lbs. heavier than passenger) - 90 lbs.
Old Nov 25, 2005 | 09:33 PM
  #323
StangEaterSS's Avatar
I just grinded my rear brake calipers to fit prostars and it looks like about a half pound of metal on the garage floor now. LOL
i have a set of ET drags and a set of M/T drag radials for the 15" prostars, the drag radials feel like they wiegh twice as much as the ET drag. dont have exact weight #'s yet.
Old Nov 26, 2005 | 05:18 AM
  #324
Larry's Avatar
Originally Posted by Colonel
6...Lightweight steering wheel
Not too sure about 6# savings. My factory steering wheel with air bag only weighs 8# 10oz. The steering wheel alone 4# 14oz.
I found this mod to reduce total weight by about 2 1/2#. I used sheet metal screws to hold the mounting plate to the assembly.
Old Nov 26, 2005 | 08:01 PM
  #325
93LT1's Avatar
Has anyone cut out that spot right above where your fuel tank is? I am going to do this soon, and all the brackets in the car. There has to be some weight savings there.
Old Dec 31, 2005 | 01:29 PM
  #326
H8 LUZN's Avatar
3000# .....!2 Wheels
Old Feb 5, 2006 | 03:56 AM
  #327
blind527's Avatar
Does anyone have any guids for removing the sound deadening in the carpet? How much noisier is it in there, how much does it weight, and is it worth it?
Old Feb 9, 2006 | 09:01 PM
  #328
Rare96WS6's Avatar
The sound deadening in my TA weighed 45.0lbs. I took all of the seats out, loosened and took out the front and back plastic panels. Took out the center console. I was albe to leave in the 2 side plastic pieces where the speakers mount. The car is louder, but it was worth it!
Old Feb 14, 2006 | 03:32 PM
  #329
hourang's Avatar
13..Lightweight springs and shocks
fyi, bmrfabrication.com advertises 17 lbs. loss per pair over stock spring/shock combination for qa1 shock/spring combo
Old Feb 15, 2006 | 08:51 AM
  #330
hourang's Avatar
this list should be expanded out to include mods that add weight, like nitrous, beafy rear, roll cage, etc. that way people know what they need to compensate for. Looks like i need to loose a total of almost 200lbs just to be at stock weight.
Added weight:
+30-40..Nitrous
+85......Moser 9" rear with truetrac
+10......Beafy Steal driveshaft
+50-80..Rollbar/cage
Old Feb 28, 2006 | 04:29 PM
  #331
Matt D's Avatar
Retired Street Racer
I weighed the stock carpet with sound deadening last night. It was 42 total. Carpet was 24 and the sound deadening was 18.
Old Mar 6, 2006 | 11:06 AM
  #332
1_Bad_LS1's Avatar
I just have a bit of info and a question...
First the question... How much do Bogarts Front Runners weigh including the lugnuts?
Now for the info... A Front Runner from Weld... The PRO Magnum 2.0 in a 15x3.5 weighs in at a wopping 7.0 lbs alone, 7.5 with the required spacer and lugnuts
Old Mar 14, 2006 | 12:43 AM
  #333
allbustedup's Avatar
Default weight reduction chart
Fourth Generation Camaro-Firebird
wheelbase: 101.1
Width: 74.1
Height: 51.3
Weight: 3436/3521 (Z-28) see details
Weight dist.: 57/43 -> 58/42 (Z-28)
Cx: 0.34
Engines
disp inj HP Torque C/R
3.4 ------- 160@? ?@? ?
5.7 ------- 275@5000 325@2000 10.5
(223@4200 HP at the wheel)
Gearboxes
? (for the base model)
T56
Auto 4L60
Rear end ratios available
(O=open, P=posi):
2.73p (1993-95 std), 3.23p (1993 G92), 3.42p (GU6 94-95), ?o
Tires: Base models ?
Z28 ?
Cam info on 4th Generation camaros
GM PN Lift Duration Lobe
In. Ex. In. Ex. Separation (in/exh)
1992-93 (Y-car) 10168506* .451 .450 205 207 117.0 (117/-117)
1993-1994 (F-car)
1994 (Y-car) 10168531* .450 .460 203 208 116.0 (114/-118)
*roller cams
Automatic transmissions
TH350 2.52 1.52 1.00
4L60 3.06 1.62 1.00 0.70
Manual transmissions
Muncie:
M21-M22 2.20 1.64 1.24 1.00
M20 2.52 1.89 1.46 1.00
Borg-Warner T-10:
V 2.23 1.76 1.30 1.00
S 2.43 1.64 1.24 1.00
W 2.64 1.76 1.35 1.00
X 2.64 1.64 1.24 1.00
CC 2.88 1.91 1.35 1.00
Y 2.88 1.76 1.35 1.00
U 3.44 2.28 1.46 1.00
Z 3.42 2.28 1.46 1.00
Saginaw:
The number to the left indicates number of grooves on the input shaft
III 3.50 2.30 1.60 1.00 (I used to have it, yuk!)
II 3.10 2.20 1.47 1.00
0 2.85 2.02 1.35 1.00 (this one is much better)
I 2.56 1.81 1.35 1.00
Borg-Warner T5:
1983 2.95 1.94 1.34 1.00 0.74
Borg-Warner T56:
1993 3.36 2.07 1.35 1.00 0.80 0.62 (std)
1993 2.97 2.07 1.43 1.00 0.80 0.62 (G92)
1994 2.66 1.78 1.30 1.00 0.74 0.50
1995 2.66 1.78 1.30 1.00 0.74 0.50
Option weights for 1995 models
The following weights were taken from the 1995 MVMA specs. (All weights in pounds). Thanks to Dave Emanuel (DFE1@aol.com).
Curb Weight Shipping Weight
Camaro coupe 3251 3171
Camaro convertible 3342 3262
Z/28 coupe 3390 3310
Z/28 convertible 3480 3400
Differential Weights of accessories
6-way power seats 7.9
Remote lock control 0.4
Power door locks 1.8
Power Windows 2.7
Remote trunk release 1.3
Rear floor mats 1.8
Body side mouldings 1.8
T-Tops 12.3
Fog Lamps 2.7
Rear defogger 0.4
Air Conditioning w/ V-6 42.3
Air Conditioning w/ LT1 48.9
Sunshades 2.7
Electric sport mirrors 0.4
Cruise Control 4.4
LT1 compared to 3.4 V-6 112.0 (with 6-speed)
LT1 compared to 3.4 V-6 71.8 (with automatic)
3.8L V-6 over 3.4 37.0
Auto Transmission 41.4 (with V-6)
Auto Transmission 84.7 (with LT1)
1LE 7.0
Bose Speakers 7.0
AM/FM w/CD 0.4
Old Mar 19, 2006 | 07:24 PM
  #334
12secondv6's Avatar
Moroso ds2 - 26 X 4.5 X 15 - 13 lbs each.
kumho 165 80's - 18 lbs each
Weld drag lite 15 X 3.5's 10 lbs each
Old Mar 27, 2006 | 01:57 PM
  #335
12secondv6's Avatar
14 more lbs gone.
Connections where front bumper supports connect were cut off
http://www.bbbracing.com/genie/DynoD...6/100_2650.JPG
Misc wiring, massaged front bumper underneath.
http://www.bbbracing.com/genie/DynoD...6/100_2654.JPG
http://www.bbbracing.com/genie/DynoD...6/100_2647.JPG
I would guess my curb weight at 2825 now?
Old Apr 4, 2006 | 07:35 AM
  #336
ss1129's Avatar
How much could you save removing the hood latch/struts/hinges/cable and replacing with 4 pins?
Old Apr 6, 2006 | 02:54 PM
  #337
TWS's Avatar
TWS
I didn't make it all the way through this thread. I read "only" 7 pages, but I've seen the passenger side airbag weighed at 13.5 and 14 lbs.
I just took mine out of my '94 Z28 and I'd swear that sucker was nearly twice that! Either there has been a change in the airbags and the earlier ones were heavier, or I need to get back to the gym and get my arm strength back up!
I guess I should weigh mine before I go babbling in this thread, but in case I forget, where is that 14 lbs figure coming from?
Has someone else weighed the passenger airbag out of a '94, or at least an LT1-era car?
One additional weight savings is the "pad" under the dash. I left mine out when I put the dash back together and that's at least another 5 lbs of savings.
Old Apr 18, 2006 | 09:45 AM
  #338
Dustin's Avatar
There is a weight difference. Pulled one out of my buddies brothers LT1 car and it weighed something around 30lbs, mine out of my LS1 car weighed 13lbs.
Old Apr 26, 2006 | 08:43 PM
  #339
HeapaShifter's Avatar
I just read through this whole thread for the first time.
I saw the stock z28 hood weighs 50 pounds. The OEM SS hood weighs a little more. The vfn fiberglass hood weighs only 18 pounds.
What about the SLP ultra Z hood? Is it close to the vfn? I'm sure it's a good deal less than the stock hood.
Old Apr 27, 2006 | 02:51 PM
  #340
Rare96WS6's Avatar
Man, why does the stock fiberglass SS hood weigh so much?! I would have thought it weighed much less than the steel Z-28 hood. My WS6 hood does not weigh anything near 50lbs.
