Drag Racing Tech
Weight reduction list!!!
Old Apr 30, 2006 | 05:38 PM
  #341
Strahley's Avatar
How does one go about removing the cruise control stuff?
*edit* Started taking some stuff off. Windshield wiper fluid tank with roughly 1/3 full weighed a little over 4.5 pounds...Can't get much more on the nose of the car than that
Old May 13, 2006 | 07:40 AM
  #342
z_speedfreak's Avatar
Originally Posted by BADZ
In the older day's they use to swiss cheese the chassis (Punch out holes of steel shims to save weight) and it would still have the strength just lighter..
acid dip =)
Old May 22, 2006 | 12:19 AM
  #343
SSwanner's Avatar
14lbs !sound deadning/insulation under carpet!!! :woot:
Old May 28, 2006 | 05:34 AM
  #344
sleeperfd's Avatar
Great thread. I will be doing this soon.
Old Jun 11, 2006 | 02:22 PM
  #345
BlackHawk T/A's Avatar
Removed spare tire, jack, rear seats, seatbelts, brackets and bolts.
Now I have holes in the floor
What do you guys recommend to fill the holes?
Old Jun 11, 2006 | 02:24 PM
  #346
daniel6718's Avatar
put the bolts back
Old Jun 11, 2006 | 03:22 PM
  #347
SPEEDYws6's Avatar
I put a dab of silicone in them.
Old Jun 11, 2006 | 03:53 PM
  #348
slolt1's Avatar
i used some black duct tape and you realy cant see the the tape it blends in with the carpet
Old Jun 11, 2006 | 04:07 PM
  #349
PlowTown Missile's Avatar
Incase no ones said it already, the best weight reduction mod I've done was use a plasma cutter on my Z28. I went a little crazy with it to trim as much excess off the car as possible but not many people can tell what I trimmed off unless there's another Z28 there to compare to.
Old Jun 11, 2006 | 05:37 PM
  #350
SPEEDYws6's Avatar
How about some pictures?
Old Jun 12, 2006 | 05:19 AM
  #351
Well i'd want something to block sound and fumes. Maybe some silicone wouldn't be a bad idea to seal it up, then cover over it with something.
Old Jun 12, 2006 | 05:16 PM
  #352
Don't have any. I trimmed the K-member, A-arms, radiator support, etc on the car. Just put it up on jacks, crawled underneath, and neatly trimmed up what looked excessive.
Old Jun 12, 2006 | 06:08 PM
  #353
mongse's Avatar
I ruin the end of films...
Youz cwazy!!
Old Jun 13, 2006 | 09:05 AM
  #354
Z28XTC's Avatar
Great thread but if you go SD you dont need maf so you save 5lb or so right?
Old Jun 22, 2006 | 09:26 PM
  #355
Trojan35's Avatar
Okay I've been searching this thread but no luck.
Anyone with Stock weights for our cars? Specifically an '00 T/A (not ws6).
Old Jun 28, 2006 | 10:17 PM
  #356
SSwanner's Avatar
!rear bumper support & hardware >21lbs
Old Jun 30, 2006 | 12:33 AM
  #357
1320 Girl's Avatar
Hey how much time would it take off the car if i put lexan windows on
Old Jul 1, 2006 | 08:12 AM
  #358
FASTFATBOY's Avatar
T-56 was in the car, now a 4l60E weight differential?
mild steel k member vs stock?
David
Old Jul 2, 2006 | 09:01 PM
  #359
SSwanner's Avatar
!cruise controll stuff on non tcs car -5lbs
!panhard cross brace -5lbs
Old Jul 3, 2006 | 10:04 PM
  #360
SSwanner's Avatar
!power steering, lines, bracketry, bolts, fulid -12lbs
