Drag Racing Tech
MWC Chromoly Fbody Cage....underway!!
Old Jul 6, 2014 | 08:13 PM
mrstepheneades's Avatar
Default MWC Chromoly Fbody Cage....underway!!
I got all the interior out off my twin turbo ta and starting on my cage I received from mwc. It's a 10pt chromoly. Just starting a picture thread on it for reference info for others and I'm sure I will have questions myself along the way.
First question I have. I know nhra rules say tig entire cage. That's no problem. But where the bars touch the floor plates, can that be mig? If it's something that is in question I'll just tig. Not like I know any chassis inspectors.
I'll post a bunch of progress pictures tomorrow when I get to a computer.
Old Jul 6, 2014 | 08:16 PM
Zmg00camaross's Avatar
In to watch. I thought the plates can be mig just not any tube.
Old Jul 6, 2014 | 08:54 PM
I heard lots of things including that it depends on inspector. I did mig weld the floor plates. I've only got the main hoop and the rear bars on so far.
Old Jul 7, 2014 | 06:27 AM
98Camarod's Avatar
I tig'd all of mine, even the floor plates. Pretty shitty, but it looks great. IIRC I found out that you can mig the floor plates. I know alot of people also tack the bars into place with a mig.
Old Jul 7, 2014 | 07:41 AM
Old Jul 7, 2014 | 08:06 AM
Well I tacked bars so they will stay in place. I tacked them in easy accessible places so I can cut the tacks off and tig later.
Old Jul 7, 2014 | 08:08 AM
The bars were suppose to go to the speaker holes or that's how I ordered it. But im not hard to get along with so I just said screw it and used the original style bars they sent lol. Still looks fine.
Old Jul 7, 2014 | 09:33 AM
ssvert99's Avatar
LS1Tech Premium Sponsor
The rear bars placed where you have them is by far the best. Going through the speaker hole places the tube over the inner wheel well where there is very little strength(or safety).
The floor plates are fine to be MIG welded, chromoly tubes are supposed to be TIG welded at any point.
Whats up with that big gaping hole in the tunnel over the torque arm?
Old Jul 7, 2014 | 10:12 AM
Put my 9" rear in and the Huge Spohn Pro Series torque arm and it was hitting the tunnel so much it looked like I put a 3" lift kit on the rear of the car because the suspension wouldn't settle. So I cut it out enough so it would move. Im going to sheet metal the area closed. Just box in around the area.
Old Jul 19, 2014 | 06:09 AM
Got the gaping hole closed up and boxed in so the torque arm can still move up in there. Just pieced it since its gonna be under the carpet. Painted black after this also.
Old Jul 19, 2014 | 07:04 AM
RENE'S RAGE's Avatar
Safety First!
Anymore progress on the cage?
Old Jul 21, 2014 | 07:54 AM
Originally Posted by RENE'S RAGE
Safety First!
Of coarse lol. Little bit more accomplished this weekend. Just haven't had much time lately.
Old Jul 21, 2014 | 07:58 AM
The bar on the driver side im having trouble getting just right. ssvert99, do I need to cut the dash support a little for the bar clearance? Or should it go in front of it fine and im just not holding my mouth right lol?
Old Jul 21, 2014 | 09:01 AM
ssvert99's Avatar
The driver side a-pillar bar is sunk into the bulkhead approximately 1/2 the diameter of the tube. Just use a body saw or cut-off wheel to clearance it as needed. This is required as the body is not the same on both sides.
Old Jul 21, 2014 | 09:13 AM
Thanks man. I already hammered it a little but realized it probably needed to be cut.
Old Jul 23, 2014 | 07:23 AM
More cage progress. Put my seat in to check things. Still a few more bars to put in.
Old Jul 23, 2014 | 07:54 AM
Looking good!
Old Jul 23, 2014 | 12:05 PM
Looking good!
Thanks man. Not a lot of run in these cars once you get a cage in there haha.
Old Jul 26, 2014 | 05:54 AM
Door bar intersection
Old Jul 26, 2014 | 08:28 AM
high impact's Avatar
I will be installing a cage this winter and have been seriously considering this exact cage. A local buddy of mine installed the same cage and the only thing I don't like are the way those front bars come down off the hoop and don't run even along the windshield pillar. I love everything else about this kit.
Looking really good!
