My results from the track
so the more air you can cram into a cylinder, the more fuel you can burn with it. that's where the power comes from. but you need a high octane, slower burning fuel to go with it to resist detonating from the resulting heat.
so if you're using a very high octane in a low compression, low heat situation, your burn rate is slow and ineffective causing very low power. it will run decent driving around, just have no power.
so only use the fuel that your effective compression ratio requires. if you really are around 9:1 static compression n\a, you could be running 87 octane and it will run better.
I've heard people say that E85 acts like anywhere from 110-120 octane.
Basically what I was trying to do is what this guy did in his first post.
https://ls1tech.com/forums/forced-in...-i-expect.html 12.20 @ 110 N/A and now he is going to turbocharge it. That was kinda what I was looking for before I put the turbo on.
it can tolerate a lot of timing especially where you are low compression I bet you could increase timing a lot ( depending on if your tuner has optimized your current setup or just laying the foundation for your turbo setup)
Alcohol fuels are also oxygenated so the fuel acts as a carrier to bring extra oxygen into the combustion chamber ,not nearly as much extra oxygen as a power adder like n20 , turbo,sc, etc.. but still extra oxygen.
Alcohol is also a very clean burning fuel and can be run pretty rich without fouling plugs so you can pack a lot of it in there possibly to take more advantage of that oxygen carrying capacity
then there is the charge cooling properties kinda like getting improved density altitude from your fuel lol - but like big hammer is saying it is a slower burning fuel due to the octane increase so you have to bring the timing in early (advance) to get it to complete combustion events in time to take advantage of the fuel or you would be better off running lower octane , I guess it all depends how soon you plan to complete your turbo swap if its worth the effort to try to maximize your current setup , low compression NA on e85 hp gains are typically mentioned to be in the 5% range but under boost its a game changer.
This is the setup I'm copying... https://ls1tech.com/forums/forced-in...-page-3-a.html
