Drag Racing Tech
Check out what is going to make me HOOK!
Old Jun 3, 2004 | 04:09 AM
SUX2BU's Avatar
Default Check out what is going to make me HOOK!
Saw these about five years ago but thought they were "too race" for me. My friend said they were a miracle cure for his big block third gen.so I'm going to build some lift bars for my car since they don't make them anymore. I know this is a "race only" set up but i don't care if it rides like a tank as long as it hooks!
Old Jun 3, 2004 | 06:36 AM
GIZMO's Avatar
Why not put ladder bars in, so that you can still adjust the pinion angle? About the same amount of work will net something that works a whole lot better. If you really want something that bolts in and works about the same, try Pete-Z bars.
Daren
Old Jun 3, 2004 | 11:44 AM
Outlaw's Avatar
In the 1st picture.. i have to question this thing.. ok if you look above and BEHIND the pan rod mount.. the guy has a bump stop on the frame right next to his battery cable? ummm what the heck is that there for?
Old Jun 3, 2004 | 11:51 AM
RyanJ's Avatar
SSU Moderator
Thats an exhaust hanger I think.
Old Jun 3, 2004 | 12:43 PM
Outlaw's Avatar
oh your right.. guess i need to go get my eyes checked and another cup of coffee
Old Jun 3, 2004 | 12:45 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I'd just get the Pete Z bars, at least you are legal for classes and it won't be as radical. Looks like bars like off of Dante's car.
Old Jun 3, 2004 | 01:33 PM
CamaroCain's Avatar
That is the southside machine setup for the third gens, but like everyone else said, you cant adjust pinion angle, the instructions say to set pinion angle before welding to the rear axle(non-adjustable). I have heard the system is great for traction though, and how many people re-adjust pinion angle after setting it?? Good luck on that setup.
Clint
Old Jun 3, 2004 | 06:09 PM
SUX2BU's Avatar
Actually i didn't even think about being legal for classes. Oh well there goes that idea. It sounded good at 4 AM.
Old Jun 3, 2004 | 09:40 PM
GIZMO's Avatar
If you changed rear tire diameter or ride height after installing these bars you could be in a world of problems!
Old Jun 4, 2004 | 12:04 AM
SUX2BU's Avatar
Ride height change would alter the Pinion angle but not Tire diameter.
Old Jun 4, 2004 | 06:25 AM
JaSSon's Avatar
Where can I see the Pete Z bars?
Old Jun 4, 2004 | 08:17 AM
GIZMO's Avatar
You're right. What I meant was that if you change the tire diameter you will also change the ride height to make everything look right. At least I would. And at that point wouldn't your pinion angle be off?
Best Regards,
Daren
Old Jun 14, 2004 | 05:14 PM
LIL SS's Avatar
Moderator
Pete Z bars. https://ls1tech.com/forums/showthrea...ight=PETE+BARS The little bit of testing on the street has felt really good. I haven't been able to play too much as I was tracking down a vibration. Hoping to have it sorted out so I can play with it this weekend.
Old Jun 15, 2004 | 10:12 PM
The Guy in MY 99TA's Avatar
damn those pete z bars were teh damndest things to figure out how they worked! Then I got to looking and noticed that they WEREN'T mounted solid to the LCA. I got it now though!
Those look like they work pretty good.
Anyone else runnin em?
Old Jun 16, 2004 | 10:33 AM
LIL SS's Avatar
Moderator
That would be pictures of my car I have been chasing down a vibration for a few weeks so I have not been able to really test them out. Now that I have the rear and driveline back in my posesion, I will hopefully be trying them out for real soon. If you do a search, you will find where I posted my first impressions (All being good).
