Bypass trans cooler
Bypass trans cooler
Anyone doing this? I thought they only thing to do is run a line from the inlet to the outlet. But I noticed a 3rd line towards the bottom of the radiator.
Can I just cap this or what's the best way to bypass the transmission?
Internet Mechanic
The thought process is that the stock cooler is limited due to hot coolant and heat soak could cool the transmission only so much. I ended up by passing mine and found longer life. I also ran a B&M cooler that allowed the fluid to get to a safe operating temp and then start the cooling process.
All I would say is do what you feel makes the most sense in how you use the car and ultimately its your $$$ if something goes wrong.
Also to note if you felt ambitious you could run a temp guage to see if it really mattered, something i never got a chance to do on my 4L60e
I have a solid input shaft and no cooler circuit in my trans with a trans brake and a 6200 converter. Thats why i said if its a track only car you dont need it. For the short amount of time its running by the time i get back to the pit it might hit 160* and thats running 8s after shutting it down at the 1/8th.
