Which cam and stall for track only?
I just picked up another LS1 with 100k on it
Trying to figure out which set up will be faster.
The car is race only 1/8 bracket car on OLSD tune.
I think full race weight is about 2650-2750
The car is on E85. 3.73 12bolt 4l60e
With stock heads 228/232 .600 112LSA cam and 3800 yank, I ran 7.2-7.4
Here is what I have:
stock LS1 heads
Stage 2.5 5.3L heads
228/232 .600 .600 112LSA
237/242 .603"/.609" 112LSA MS3
I would love to take advantage of the E85 and bump compression up, but not sure about PTV clearance. Could heads be shaved?
Also should I restall my converter?
I want to get all I can get out of the car, but want to shift at 6500 max. I race it a lot.
I am hoping for 6.8-6.9
Right now I run 26" et streets and it shifts right before the finish line.
I was thinking about trying 29.5" tires to get it to only shift once and be at full power at the stripe. Right now it suck not having power at the big end if I need to get out of it and get back in it to drive the finish line.
I also have a set of comp lifters with about 3k passes on them. They were in an engine that blew before this one. Would it be worth installing them or are they junk?
Some other things I have from that engine are ARP bolts and Rollmaster double roller timing chain. Also ported oil pump.
A 28" tire with a 4.56 in high gear and guessing about 15% slip in the converter at the 1/8th: 6500 rpm should net you around 103 mph with should put you in the 6.80 range. At 2700 lbs, it'll take around 450 horsepower to net 103 mph, which should be doable with the combo above.
Happy drag racing!
Yank converters are great for a guy that wants to drive around, but if you're looking for ET, I wouldn't go that route. Never seen one run right as a good custom one will.
http://www.corvetteforum.com/forums/...post1585448394
I'll put my UCC and Neil chance converter up against any yank converter any day.
I wasn't even gonna go there. They're just baby fish in a big pond, let them play and have their fun.
I'd call Greg and see if he can redo your yank converter OP. Or sell it to one of these guys that think they are gods gift and see what Greg can build you. They are reasonably priced and will for sure perform like you're looking for.
