440ci with a 600 shot @3900lbs = ? ET
Location: From the Bowels of Hell!!! You want some of me bitch?!?!?!
1 Post
There is a car in N. La. that claims to have a 600 shot of N2O. He says it's a dry shot but you can plainly see it's a DP setup. He says it will run 8's, and weighs ~3900lbs. Here is a link to the car.
http://www.ls2.com/forums/showthread...5&pagenumber=1
so it has fart pipes and is grossly overweight. also looks like C5r heads as well. :shrug: really really a lot of stuff in that car.
as for my prediction, IF he can get the chasis fine tuned, i think a 9.60-9.70 bast case scenerio assuming he can run mid 10s on motor. at that weight and power level i wouldnt want to tune that suspension.
1 Post
Well they said they are AFR heads and a C5R block. But those heads have been on the car for a month or so and the AFR's have just hit the market this week I think.
Actually from my experience DRY is safer,u are using an injector to meter the fuel.With the proper fuel system its pretty simplified as long as an injector doesnt crap out.No back fires or bad distrubtion of fuel to pudlle in the intake tract.I ran over 100 bottle threw my DFI controlled LT1 car and never even nicked a plug.
By the way that was a 200 shot though and I do agree it would really need to be fined tuned.Wet will make more power in the long run,the SEFI can control wet too although I know nothing about how it works or controls the noids noe do I like that way of spraying N20 but to each is own.
Mike
LS1Tech Co-Founder
Sweet car, I occasionally have heard of this car.
I would say that it's probably high high 10's on motor and then mid 9's on the can. That raceweight is very heavy.
I would rather run a dry setup for a 600 shot then a wet.
I built the exhaust at the shop i worked at for that car. Its not how I would have built it but its how the customer wanted it. Thats what matters and thats what he got.
Mike
The car has everything it needs and some to run high 8's i believe. The car even has some lightweight aluminum wheelie bars which are cleary disconnected at the time of the pictures.
This was a turn key deal done by Keith Craft Motorsports here in Dallas.
1 Post
If he can get that 3900lb car to pick the wheels up, and need wheelie bars, on that suspension set up, then whoever set the suspension up is a God. MADMAN, would that be you? LOL
