Front/Rear Afco Shock settings
Ok fellas , I'm bout to start making test hits with my whole new setup finally , ride height , dragbar , TA is all setup , I'm wanting some good initial settings for compression & rebound for front and rears . Car is roughly 3250 lbs with me in it , Six speed , 4.56 gears and running a MT 28x10.5 stiffwall slick , car is making around 560 to the wheels
I would start with the rear at 8 from full stiff on compression and 8 from full soft on extension, front I would put 10 from full stiff on compression and same for extension, and see what that gets you.
12-13 lbs of air in the rear tires.
what springs do you have on the shocks, not that I would change what I suggested.
Was really cool at first, but cost a lot of money to fix!
To each their own. My car was not able to do a large enough wheelstand to hurt the car until it made 931whp. It was on full loose all the way up to that point. It also sixty foots in the mid 1.2's. So in my experience, I doubt the OP is going to do a bumper stand with 560whp at his weight. However, I have seen tons of cars around his power level, that don't get enough weight transfer, and the front shocks pull the front of the car back down to unload the tires and induce spin. This would be especially a problem with manual setups. It is very popular for manual trans guys to run 90/10 shocks on the front, which is essentially a full loose shock.
Transam69230, your car is no comparison to the OP, and neither is mine. Apples to Oranges. That would be like me suggesting to the OP that he needs to stretch his wheelbase 20" because his car could become unstable when he traps over 220mph in the quarter.
I guess NA setups are for pussies , lol .....I Plan on throwing a plate system or dropping compression and run an F1x down the road , just trying to get mid to low 10's out of my car as is before I do poweradders , u boys got some badass rides , thanks for the help , Ive got a few different option to try out now on the shocks
Travel limiters work but I would not add them until you are at full stiff on extension.
I would stiffen the compression before loosening the extension that far, the unloading a stick car will have issues with the car u loading this will help stop the nose from dropping g enough to unload.
I'm not saying full loose can't work but starting off there is not a good idea, if the car wants to come up at all that's going to really let it.
Afco recommends shocks to be full soft on cars slower than 9.90... just sayin'
https://www.afcodynapro.com/content/...ning1766354666
