Any ET/MPH guesses fo LS1 RX7
Well I am heading to the track this friday for my first real shakedown passes with the new setup. Here is the setup what do you think I will/can run both ET and MPH.
1993 RX7 with an LS1
Car weight with driver 2850 lbs
4.10 rear
200-4r transmission with transbrake
SS3800E converter
NXL DP kit jetted for 120shot
ET Streets
Stock motor except 3" mandrel custom exhaust and a cold air intake
Rev limiter raised to 6700 shifting at 6500rpm
Assuming track conditions and weather are good.
I am hoping for high 11's off the bottle and low 11's on the spray, what do you think.
Mike
4.10 rear
SS3800E converter
ET Streets
Mike
I have all stock internals. Like I said shifting at 6500 but the limiter will be at 6700 just in case. I will probably shift at 6300 just to be safe but we will see.
I will be doing backflips if I crack off a 10!!
He is a friend of mine from Flordia but that was in a 6 speed car and a different setup. I would post pics but I have no way to host them.
I will hopefully have a video of the passes on friday so I will post up.
I agree I am way over geared unfortunately there is VERY little gear selection for RX7's (Only 3.90, 4.1, 4.3 and 4.56) but I am in the process of getting a rear subframe that can support a ford 9" which opens up my gearing options.
I will also have a friend there with a set of 28" tires too so I can always try those.
