Drag Racing Tech
what to do?...Gear choice for 385
Old Jun 17, 2004 | 08:12 PM
CHRISPY's Avatar
Unhappy what to do?...Gear choice for 385
Hi guys,
I have a dilemma...
My car currently has 3.73s in it and I am running M&H musclecar drags on the street (26.3 overall height).
This should be a great street combination but the gearing isnt ideal for the strip.
My 385 buildup is just about done and I need to decide what to do about rear gears. Projected power is in the 465-485RWHP and similar torque. Peaking approx 6300-6400rpm
Car weight is hopefully going to be in the 3400 pound range with driver.
Tire size is 26.3 on the M&H tire and probably a 26x10 ET drag I am going to borrow occasionally for the hardcore race days.
Now what gear should I go with? I want to balance street driving with great track performance.
I have 3.73's and will be undergeared with this tire with my current power level.
I dont want to rev the car to the moon. Looking to have the shiftlight at 6400rpms and actually shifting around 6600rpms.
4.11s will give me 127.8mph at 6700rpm through the traps on a 26.3 tire with perfect hook
3.91s will give me 134mph at 6700rpm and 130mph at 6500rpm
My current 3.73's will give me about 140.5 at 6700rpm and 136mph at 6500rpm
My projected trap speed should be in the 127-128mph range give or take a mph.
The 3.91s sound like an ideal combo for both street and track but I have heard they are noisy as hell.
The 4.10s look to be the best choice for drag racing but will I hook on the street?
What are your thoughts?
One constant is that I am staying with a 26.3 tall tire.
I am going to street drive a lot and think 4.10s might be a bit much with that power level?
Your thoughts appreciated!!!
Old Jun 17, 2004 | 08:28 PM
The Juggernaut's Avatar
here is what I would do.
Get everthing done, take it to the track and see what happens.
Then go from there.
it may work ..it may not.
Until you try it, you don't know.
Old Jun 17, 2004 | 09:33 PM
theblur98ss's Avatar
I agree with 01Z. From 3.73 to 3.90 isn't a real big change anyhow. If you have a street/strip car I think 3.73 might be the best of both worlds for you.
Old Jun 17, 2004 | 11:15 PM
SilverGhost's Avatar
Motorboater
4.10 on a 26" tire works well for me on the street, but i can't hook it at the track. i am pretty sure i'm undergeared and too small of a tire, i keep spinning bad even on mid 1.5 sixty foots.
i wouldn't go smaller than 4.10 if i were you. but i def agree with 01-butthead, leave it, go make shakedown, and then decide what's best for the new combo.
Old Jun 18, 2004 | 07:59 AM
Coach 02 A3 Z/28's Avatar
"The Drag Racing Director"
Thumbs up
I agree with everyone above.
Coach
Old Jun 18, 2004 | 08:21 AM
CHRISPY's Avatar
Thanks guys
I'll see how the 3.73 works out and then switch if necessary
Old Jun 18, 2004 | 10:11 AM
next's Avatar
I have a similiar issue with changing trannys and deciding between a 4.30 and 4.56 based on some gear calculators. Decided to do the same and run my current 3.70s on some shakedowns and then make the decision.
Old Jun 24, 2004 | 07:51 AM
CHRISPY's Avatar
My car gets tuned today and I'll make a gearing decision based on what the numbers are and where the car peaks (RWHP and RWTQ)
Probably going to go with a 4.10 but will wait and see
Old Jun 24, 2004 | 08:00 AM
Big Mike's Avatar
Go with 4.10's and a 28" tire!
Old Jun 24, 2004 | 08:43 AM
CHRISPY's Avatar
already have a 26.3 inch tire
Where I am staying motor I think a 28x10 and a 4.30 would work perfectly.
Old Jun 24, 2004 | 09:38 AM
Big Mike's Avatar
You are absolutely right! So ditch the 26's, slap on a 28" tire and gear that **** to high hell!
Old Jun 24, 2004 | 09:55 AM
CHRISPY's Avatar
LOL!!!
The wife'll kill me if I spend more money on both slicks AND gears now LOL!!
Old Jun 24, 2004 | 10:32 AM
Chris, I feel your PAIN Brother!
Coach
Old Jun 24, 2004 | 12:19 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Did you sell those 28 inch slicks? I would use those and 4.10's.
But I would go like Sean said and take it to the track and see what happens.
Old Jun 24, 2004 | 12:32 PM
CHRISPY's Avatar
Slicks are sold but not picked up yet...
I'd prefer to stay 26 inch for fitment reasons but am not completely against it though
Old Jun 24, 2004 | 12:34 PM
JL ws-6's Avatar
Race your car!
next year I'll be running 26 inch tire with 4.30 gears, I'll be nowhere near the power level you are at, and I have a M6. If you had a 9 inch, you could try 3.89 or 3.75 gears, I know a couple guys that run that in mustangs with similar power levels (470ish hp,450ish tq) to you on 26 inch tires. Car's are in the 3400 race weight range, and are running low 11's high 10's, depending on the day. Depends on your converter too, they are all running 3500 to 4000 stall converters. Know
Old Jun 24, 2004 | 12:44 PM
CHRISPY's Avatar
I am shooting for 10.70s in full kill mode with this combo.
I think 4.11 and 26.3x10 is the best compromise so far.
That or a 4.30 and 28x9 ET Drag
Old Jun 24, 2004 | 12:47 PM
LS1Tech Co-Founder
I think 26x10.0 slick + 3.73's is a good start. I think hooking a 26x10. and 4.10 might be trickier.
Old Jun 24, 2004 | 01:20 PM
JL ws-6's Avatar
Race your car!
John, you think that hooking a 26x11x15 with 4.30's on a M6 car will be a problem, say when I get to about 420+ RWHP? I assume with the power I have now, it won't be a problem.....
Old Jul 20, 2004 | 02:26 PM
CHRISPY's Avatar
Update
Just ordered 4.11's
The M&H tires I have are actually measuring out to be 26.5 inches tall. With .4 of an inch tire growth at 125mph I should be ok and crossing at ~6300-6400rpm.
I'll let you know how everything works after I get the gears installed and hit the track
