Drag Racing Tech
Battery shut-off switch?????
Old May 12, 2002 | 08:57 AM
y2kss1603's Avatar
Default Battery shut-off switch?????
Question for those of you who have relocated your battery and installed a shut-off switch. What connection points up front did you use to insure "complete" shut down? My battery is in, wire is run, now for the final connections. Thanks,
Eric
Old May 13, 2002 | 03:29 PM
y2kss1603's Avatar
Default Re: Battery shut-off switch?????
ttt
Old May 17, 2002 | 01:33 PM
Tom the roofer's Avatar
ttt
Old May 17, 2002 | 02:13 PM
Tums's Avatar
Any car with a relocated battery must be equipped with a master electrical cutoff, capable of stopping all electrical functions including ignition (must shut the engine off, as well as fuel pumps, etc.). The switch must be located on the rear of the vehicle, with the "off" position clearly marked. If the switch is of a "push / pull" type, then "push" must be the motion that shuts off the switch, and plastic or "keyed" typed switches are prohibited. Also, the battery must be completely sealed from the driver and/or driver compartment. This means a metal bulkhead must separate the trunk from the driver compartment, or the battery must be located in a sealed, metal box constructed of minimum .024 inch steel or .032 inch aluminum, or in an NHRA accepted plastic box. In cars with a conventional trunk, metal can simply be installed behind the rear seat and under the package tray to effectively seal the battery off from the driver. In a hatchback type vehicle the battery box is usually the easiest solution, since the alternative is to fabricate a bulkhead which seals to the hatch when closed. At present, Moroso is the only company which offers an NHRA accepted plastic battery box, part number 74050. All I have been involved with were rear mount batteries with the cut off connection right there. The shortest distance it can be installed from the battery safely to cut power is recommended in order to prevent fires in a accident.
<small>[ May 17, 2002, 02:21 PM: Message edited by: Tums ]</small>
Old May 17, 2002 | 05:16 PM
Hey thanks TUMS. What I really want to know is the hook up. My installation for my battery in the rear is the red (positive)wire from the battery terminal to the cut off switch and the same wire from the other side of the cut off switch through the fire wall and then to under the hood. Then the positive terminal that once was hooked to the battery is now connected to the new wire from the cut off switch. This installation DOES NOT cut the engine off right away. The engine stumbles for 15 to 30 seconds then cuts off. What is the proper installation??
Thanks
Tom
<small>[ May 17, 2002, 05:19 PM: Message edited by: Tom the roofer ]</small>
Old May 17, 2002 | 08:40 PM
Brady's Avatar
LS1Tech Sponsor
Tom, you need to wire the alternator hotwire back through the cut-off switch. It's what's keeping the car running. Usually #4 wire will work sufficiently.
Good luck!
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
Old May 17, 2002 | 10:24 PM
Thanks Brady, I'll do it <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old May 18, 2002 | 05:26 AM
y2kss1603's Avatar
Thanks Brady!
Question? To save some wire,could a guy install a small relay to take the alternator field wire out of the circuit when the battery is shut off? Or would the relay current draw be too much on the battery?
Alright, no laughing out loud....
Eric
Old May 18, 2002 | 07:33 AM
Brady's Avatar
LS1Tech Sponsor
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by y2kss1603:
<strong>Thanks Brady!
Eric</strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">You could probably do that, and it would work; but it wouldn't be NHRA legal.. It would take a picky tech to find it..
__________________
2016 Z07 Carbon
Old May 18, 2002 | 11:36 AM
Tums's Avatar
Looks like you guys got it worked out. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Old Jul 10, 2003 | 06:16 PM
Good luck!
Brady, It took me awile but I finially did it. It works like a charm man. We did my brothers 69 SS Camaro too
Thanks Brady,
Tom
Old Jul 10, 2003 | 06:37 PM
Brady's Avatar
LS1Tech Sponsor
Damn you know how to drag up and old post
Glad it worked out for ya!
__________________
2016 Z07 Carbon
Old Jul 11, 2003 | 08:26 AM
Yup, I drug it up from the past because it works and it is good info.
Tom
Old Jul 11, 2003 | 01:19 PM
Moose's Avatar
Tom,
Can you take some pictures or give me some more details, I'm getting ready to do this on my car, and not real sure how..
Moose
Old Jul 11, 2003 | 01:51 PM
DERTY's Avatar
The Bull
It's pretty simple. If the car is running, the alternator is supplying all the power and the motor is the ground at that point. If you break the ground on the battery nothing will happen. So, instead you simply route the power of the alternator through the battery side of the disconnect switch. #2 or #4 Should work. Then you run another #2 or #4 up to the fuse box and a jumper over to the starter off the disconnect side of the switch. I just used an audio terminal distribution block to jump over to the starter from there, you can also get a bulkhead fitting from summit for 10 bucks to do the same. The rest is simple, battery goes to ground and the positive goes to the switch.
