Drag Racing Tech
Bmr k member, moroso 20142, speed engineering 1 7/8 installed pics
Old 05-04-2017, 05:36 PM
jblankenship's Avatar
Default Bmr k member, moroso 20142, speed engineering 1 7/8 installed pics
Just wanted to show some pics of the parts together. I've been getting a drop in oil pressure on launch so I wanted to swap to a deep sumped pan. I installed a bmr k member, moroso pan, and speed engineering 1 7/8 headers at the same time. I chose the moroso 20142 with built in oil filter housing. I also used moroso 24050 pick up. The pick up needed minor trimming on the leg where it bolts to the main cap stud. I also had to trim the sides off the stock baffle where it rolled on the sides. I also shimmed the pick up down about 3/16 with washers to get the proper clearance from pick up to pan. The pan has no clearance issues with the bmr k member. The speed engineering 1 7/8 headers hit the oil filter on the drivers side. I marked it with a sharpie, pulled the driver header back out a couple times and had to dent them in until it had about 1/4" gap around the filter. The header was barely touching the filter to begin with. My old y pipe was on using pace setter headers with welded on 3 bolt flanges. These headers lined back up perfectly. So I just welded 3 bolt flanges on these headers. This pan is 7/8" closer to the ground with 7 qt capacity, with pf61 filter and the new headers everything is nearly even for ground clearance. I am also using the output on the pan for my oil pressure gauge. I used a 1/4" npt to 1/8" reducer with a 90 degree 1/8" to 4an fitting. Then a 4an line to the oil pressure sending unit. My lower control arms were seized on my factory k member so I took a chance on the ebay lower control arms. All seams well so far. I finished it off with a spohn bump steer kit.
Old 05-04-2017, 08:05 PM
blk00ss's Avatar
Looks awesome man! I really need one of those pans.
Old 05-04-2017, 08:47 PM
Thanks man, was a lot of work, especially setting up the bump steer kit.
Old 05-04-2017, 10:19 PM
blk00ss's Avatar
What did you go with it for? Looks like you still have power steering?
Old 05-04-2017, 11:27 PM
BOLO's Avatar
The oil pan looks really nice, except the oil filter placement is a little too close to the headers to my liking.
Old 05-05-2017, 07:06 AM
Toe was moving in and out over front suspension travel.
Old 05-05-2017, 02:49 PM
LS1Tech Premium Sponsor
BMR Sales2's Avatar
I think I spoke with you on the phone about this a couple weeks ago. Glad to see it all worked out!
__________________
Glenn ***
Sales Tech
www.bmrsuspension.com
813.986.9302
Find a Quality alignment shop near you!
Old 05-08-2017, 09:53 PM
The Cartel's Avatar
I'm going to look into this pan! Thanks for sharing
Old 06-06-2017, 07:02 AM
sillysspeed's Avatar
Did this pan solve your oil pressure drop on launch?
Quick Reply: Bmr k member, moroso 20142, speed engineering 1 7/8 installed pics
