What should i be running cant seem to hit 12s.
Ok so i went to the track today and was running 13.4s at 110 mph my 60' times sucked 2.4-2.5. Last yr before i but 4.11s i i was actaully hooking and my best time was 13.06. The car is 97 trans am m6 car it makes 400 rwhp it has a moser ford 9" with 4.11s. I no the car is capable of alot more.
What tires are you running? That 60' is horrific.
You get that 60' down to even a 2.0 which is not hard even in a M6, you will be running low to mid 12's at the very least
Ya i got the nitto nt555 drag raidail extremes. Last yr when i had 373s i would back the psi down to 18 and i would hook good i was running 1.8-1.9 60' times. Now that i have 411s its spin city. I was leaving about 3k
Little tricky trying to launch the stock, definitely need some better tires but i don't see why a 1.7 / 1.8 60' isn't possible with what you have currently. That alone would put you mid 12's at least. You just need some seat time it sounds like. Can't just dump and floor it like it is it's not setup to handle that. Keep at it.
