Where should my shift points be? Graph inside...
What about ideal launch RPM? The 2 step is at 6000 now. Track prep usually isn't ideal, but it's decent, and it spins a couple rev's max off the line.
Thanks,
Craig
also if you are racing at KCIR, they prep the track pretty well. with your tq, moser, and clutch, you should be pulling 1.59 or quicker. i know i have at that track (used to live near there). 26" et streets and manual trannys have never gone well together for me or my friends that race up there. think about an et drag.
I wish I was racing at KCIR, that's a decent track. The track I usually go to is basically a strip of pavement out in the middle of a field. My best 60' so far is before the new cam and it was a 1.64 on a 5500 dump. My shiftlight is set at 6600 so I probably actually shift at 6700 (I'm slow LOL).
I'd like to try some taller ET Drags, something that has more sidewall. I wish they made a 27" X 10.5". I think a 28" would slow me down. And, the 26 x 16's just aren't very consistent.
At our track the 28x9 work great. Also the 28x9 are the soft compound, where as the 28x10 are the med to hard compount.
David
I guess the basis for asking my original question is to figure out how you determine optimum shift points. Doesn't it somewhat relate to the trans. ratio's also to keep the rpm's from dropping below peak tq on each shift? It has to do with more than just the peak of the hp curve correct?
And, how much do you think I'm giving up in ET by not shifting at 7000?
Thanks for the help guys....
But the very best way is to race and play with the shift pints.
I'm gonna set them 6500/6400 and be done with it...
Your car really pulls right to 6500 but falls off quickly..
I'd shift yours around 6700 on the 1 to 2 and 6600 on the 2 to 3.
As you can imagine, optimum shift points for a high stalled auto with a shift extension of 5900 on the 1-2 will be different than with an M6 with it's HUGE RPM drop between 1-2.
Joel's right, experiment, experiment, experiment!
Go out and race the car and find out what it likes by shifting higher on the 1/2 or lower and the same for the 2/3 until ET falls off.
I'm sticking w/my 6500/6400 theory and leaving well enough alone
taht would put your shifts in teh 6800-7000 range(right around where gator suggested). i would suggest leaving at a slightly lower rpm, go down to say 5700, and try hitting the shifts at 7000.
good luck
later
tim
so that i use the whoel hp curve up as i get to the traps. i know what you are saying. i have seen both schools of thought work equally.
shifting for torque usually results in less mph for the same et, dunno why.
i have always managed to make a tenth or so that way. when i shifted my cars for hp i always gained a bunch of trap speed and didn't seem to get any et out of it though.
later
tim
