Drag Racing Tech
My Stock Internal A4 buid thread...10's???
Old 12-16-2023, 07:27 PM
  #41
Magnet's Avatar
Pulled some more weight out today as well as worked on mounting the vacuum pump and the ram air.
Clearanced radiator support for ram air: 11.3oz
Cut V bar support for ram air/weight: 13oz
Overflow tank: 1lb 6.4oz
Driver side under fender metal: 6lb 3.5oz
The following users liked this post:
Threadzy (12-17-2023)
Old 12-24-2023, 11:37 PM
  #42
BFK86's Avatar
Where did you get that billet AC line block off plate?
Old 12-25-2023, 09:50 AM
  #43
Magnet's Avatar
Hawks. Actually got mine off eBay from Hawks
BFK86 (12-25-2023)
Old 01-04-2024, 08:58 AM
  #44
promod1955's Avatar
Cool to see people showing interest in the stock internal stuff again. I’ve thought about sticking a stock LS1 back in my Firehawk and making another run at the record.
The following 2 users liked this post by promod1955:
Magnet (01-13-2024), Tuskyz28 (05-09-2024)
Old 01-04-2024, 10:26 AM
  #45
Magnet's Avatar
Glad to see someone still around that remembers the fun!
You should absolutely do it to the Firehawk!
Old 01-12-2024, 01:55 PM
  #46
Magnet's Avatar
Have been working on this quite a bit but behind on update posts.
Lost another 6lbs 1.6oz from driver side inner fender metal. Total of 12lbs 5.1oz from inner fender removal.
Threadzy (01-13-2024)
Old 01-12-2024, 03:06 PM
  #47
Magnet's Avatar
Swapped standard battery for lithium Antigravity ATX-20 battery.
Standard: 27.8lbs
Antigravity: 3.8lbs
Lost: 24lbs
Old 01-12-2024, 08:53 PM
  #48
Magnet's Avatar
Under the car and found a few old exhaust hanger still on the car and the worn out bump stops.
Bumps stops: 1lb 5.9oz
Exhaust hangers: 2lb 4.2oz
Total removed: 3lb 10.1oz
Old 01-13-2024, 10:33 AM
  #49
BFromTheD's Avatar
She already runs really good with the stuff you had done. Should be deep in the low 11s once you get it back on the track.
Magnet (01-13-2024)
Old 01-13-2024, 10:39 AM
  #50
Magnet's Avatar
Thanks man. Yea that’s the hope. If I get everything done and good air I think I could clip high 10s, but am going to the track next week and hoping for mid to low 11s with what’s currently done.
Old 01-13-2024, 10:42 AM
  #51
BFromTheD's Avatar
That intake and ram air should make a huge difference in conjunction. Good 5 mph in identical air I would bet once the tune is optimized. The crazy thing I was thinking about is how many modern sports cars DONT run the numbers you already run. Just goes to show you how unoptimized most cars are these days.
Old 01-13-2024, 11:06 AM
  #52
Threadzy's Avatar
Coming along nicely!
Magnet (01-13-2024)
Old 01-13-2024, 11:11 AM
  #53
Magnet's Avatar
Thank you!
Old 01-13-2024, 11:48 AM
  #54
FinalCam's Avatar
Definitely keep us posted! Stock internal builds are amongst some of my favorite builds. Love lower HP higher optimization builds.
Magnet (01-13-2024)
Old 01-13-2024, 12:28 PM
  #55
Magnet's Avatar
Something about the chase that makes it all worth it!
Old 01-13-2024, 01:14 PM
  #56
Magnet's Avatar
“Mind the ounces and the pounds will take care of themselves.”
I bought an extra radio trim bezel and cut extra material off the back and then filled the holes with .5 carbon fiber.
Stock bezel: 1lb .31oz
Lightweight bezel: 8.7oz
Lost: 7.61oz
Obviously could have lost more by just removing it altogether, but I have visual standards and don’t want it to “look gutted”
I also removed the radio and HVAC controls of course.
Radio: 4lbs 5.3oz
HVAC controls: 12.3oz
Total: 5lbs 1.6oz
Old 01-13-2024, 09:21 PM
  #57
Threadzy's Avatar
It’s the little things!
Magnet (01-14-2024)
Old 01-14-2024, 06:14 PM
  #58
Magnet's Avatar
Removed stock seats and installed Kirkey on Racecraft brackets.
Stock leather/power drivers seat: 40.4lbs
Passenger leather/manual seat: 31.4lbs
Racecraft bracket: 7lbs
17in Jegs black “Kirkey” replica seat: 13lbs
Passenger bottom seatbelt: 8oz
Lost: 52.4lbs
**Note: the new style Racecraft brackets seem very over built and 7lbs. I plan to either trim them up or to trade out for an old style set that seem much more streamlined. I didn’t realize there was a difference until I was looks at old install pics to compare. I think there’s also weight that could be removed from the seat without messing with integrity
Old 01-14-2024, 07:08 PM
  #59
Magnet's Avatar
This is the difference in Racecraft brackets I noticed. If anyone has some of the old design around I’ll take them off your hands
Other things I’m thinking about/researching LMK if you have input/experience:
-Innovators West 10% underdrive pulley. Seems to be significantly lighter/superior to SLP pulley
-Improved racing Crank scraper
-Polished ring and pinion Mikronite etc
Threadzy (01-15-2024)
Old 01-15-2024, 10:07 AM
  #60
Magnet's Avatar
So I dynoed the car and decently happy with it. Still some loose ends to tie up power wise, but it made 364rwhp through unlocked converter and heavy street wheels (54lbs each) which seems healthy. Dynojet SAE not a happy dyno lol
Also proved the vacuum pump concept on a stock internal car. It picked up a tad over 11rwhp over baseline with GZ Motorsports pump and set at roughly 10in on back to back runs just swapping the belt onto the pump no other changes.
we couldn’t get a clean tq number with the converter unlocked.
The following 3 users liked this post by Magnet:
BFromTheD (01-15-2024), RMCosta (01-17-2024), Threadzy (01-15-2024)
Quick Reply: My Stock Internal A4 buid thread...10's???
