LS1 Motor Plates Now Available Through APE!
Under criminal investigation for fraud
We are now offering prefit aluminum LS1 motor plates for 4th gen F-body's. These plates come with everything you need to install it in your 4th GEN!! The kit comes with the following components:
.250" thick custom precision laser cut aluminum motor plate
(2) Prefit precision laser cut steel mounting brackets
(6) Grade 8 3/8" bolts, washers & nylock nuts
These motor plates are the best on the market and require NO cutting, grinding or fitting on the customers end! Simply take them out of the box, weld on the mounting brackets and you are ready to install your engine. Simple as that!!
We have these on the shelf ready to go!!
The complete kit price is $195.00
PIC's will be posted later tonight
Originally Posted by Chris@AP-Engineering
Yes, we do!! You are looking at $85 for the mid plate
with this kit, is there any other modification needed? such as making the waterpump mate up to the plate and the plate to the block? if you have the front plate is the rear plate (mid plate) absolutely nessecary? i'm thinking about building a nitrous motor for the Z and this looks like a good option. let me know please. thanks
All you will need is a couple of extra water pump gaskets. Two in back of the plate and two in front of the plate. No other work to get this plate to mount up. The mid plate is not a mandatory item but, is suggested.
