Calling all who run MT ET STREETS 28x12.5x15
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
What is your suspension setup?
What do PSI do you run these tires at?
I still got a lot of suspension stuff to play with, hal settings and what not, but I've only cut a 1.58 60' so far with these tires.....
I can't hook for anything off the brake......I run them at 14psi, they are not tubed or screwed either
just run them between 10.5 to 11.5 depending on how much your car bites. if it bites hars and cups them at 10.5 then run 11.5 to maybe 11.75 and you'll see a big improvement or the current 14psi you're running now. i run mine right at 11.5 and cut high 1.4's to low 1.5's on motor and mid 1.3's on the bottle with a 28x12.5 et street.
