Torque arm and 60ft questions
My existing setup is a 98 Z28 A4 W/4000 stall and 3.73 gears with a race weight of 3350. I run skinnies and slicks. My existing suspension is Hal Rs with Hal springs up front, Hals on the rear, Spohn 1” sway bar, BMR LCA and LCA relocation brackets, and a BMR Kmember, and a airbag in the RR.
The car pulls consistent low to mid 1.5 60’ times but I need to get in the 1.48-1.50 range.
Will the addition of an adjustable torque arm that does not mount to the transmission get me there?
How do people pull 1.45 60ft times in these cars?
Thanks
John
Thanks
John
Phil
Phil
Thanks for the info. Man you have a 60 footing animal on your hands! A 1.49 on the stock TA is great. I think I will need gears to get in the 1.48 60' range.
How does your car run in the 1/8 and 1/4?
What is your engine combo?
Thanks
John
Good luck.
Good luck.
How do you set the pinion angle with the stock TA?
That is no flex in the TA?
John
Switched over to an Alston TA, 9inch, TH400 w/brake and went 1.42 on a 28" hoosier on a nitrous pass. With a little more tweaking I think I can dip into the 1.3's
badass 2002 z28--- How long did it take for you to install the Alston? I got a sale going thru Phil at FLP and will be ordering one Jan 1st. It wil be about 5 months before I can install it, but figure get the inside scoop now. How do you like it also? Solid, no noise, etc...
Does it come with a template showing where to drill for the underside plate?
If the car leaves crooked putting a better rear swaybar would help.
PSJ – Thanks for the reply.
Magnus did but with a 2900lb race weight.
I might have to try a YPT4400 and see how it does and maybe some 4.10s as well.
John
