Radial street-strip frontrunners.....
When is a major tire mfg. going to make a high speed-rated 26"-28"x15 Radial street-strip frontrunner? I'm tired of these un-balanceable pieces of crap VW-bug style 165x15 radials that we have to put our lives in our hands with every time we cross the finish line w/our cars. They're making radial street-drag rear tires--even radial full slicks. Why can't someone make a high quality skinny speed-rated radial frontrunner? Comments? WJ
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
They are not radials--they're bias-plys. They're also heavy--but I'm not cutting your tires down, by any means. With Radial Drag rears, you should be running radial speed-rated good quality fronts... WJ
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
My impression of "speed rating" is for sustained speed and the heat that gets built up. Z rated tires can handle high speed heat better than H rated tires. That kind of thing.
With drag racing, you're at higher speeds for a few seconds at most. Not really enough time to get a whole lot of heat built up on the fronts. Anyone ever measure the temperature of front runners after a 130 mph pass?
I believe that someone introducing a speed-rated 26"-28" x15" Radial skinny frontrunner tire for the '05 Drag Race season, could become VERY rich in a VERY short period of time. There are tons of people out there with a need for a speed-rated, high quality street-strip frontrunner radial..... WJ
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
Originally Posted by WJ SOM SS
They are not radials--they're bias-plys. They're also heavy--but I'm not cutting your tires down, by any means. With Radial Drag rears, you should be running radial speed-rated good quality fronts... WJ ![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
Originally Posted by DrkPhx
The car is much more stable with the front runners at the track and on the street. They also track straighter than standard radials up front and much lighter than my 18" tires/wheels. No comparison and it works.
10 & 11 Second Club
I have just recently bought a set of MT Sportsman frontrunners and drive them to the track and back w/ drag radials. They drive real good on the street/highway. I used to use MT drag frontrunners and drove to the track and back, they sucked on the street and would grab every rut or bump in the road (not good) + they wore out quick. I`ve also seen 8sec cars using MT Sportsman FRs traping over 150mph in the 1/4, thats enough for me.
What are you running on rear? Street and track? Radials or Bias ply? WJ
Originally Posted by CamaroCain
I have hundreds of track passes and even a couple hundred driving miles on radial skinny fronts with no issues at all. I run the Kumho Steel Belted Radial 771 165r15's.
But, it never hurts to have more selection
Originally Posted by JS
Dangerous tire those junk metrics...
Sure u can runem but I'd hate to see it deflate in 1 sec going 10's![Icon Eek](https://ls1tech.com/forums/images/smilies2/icon_eek.gif)
I heard threw the grapeving M/T was working on a matching front radial to match their rear drag radial.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
JS: That's what I'm looking for--a speed rated radial that won't mind some heat build-up on a 100 mile interstate drive to the track on a 80-90 degree day at 65-70 mph for 1.5 hrs, then make a few 112-113 mph passes without any worry and turn around and drive home that 100 miles w/out changing tires. (The rears I change--fronts I don't want to or have the room.) Between rear slicks, small toolbox, small floorjack, a pr. of small jackstands, and a few misc. spare parts, along w/a 2.5 gal racegas container and my cozy kooler lunch box---I can't fit frontrunners in my SS hatch area--even if I DO end up removing the rear seat! Track passes only--the cheapo metric 165x15's may be o.k., but heating them up on the interstate for a hour on a hot day--then a day at the track---I just can't feel comfortable doing it....Only my opinion, though. Oh, forgot. I stuff a portable air tank in the back there, too.... WJ ![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
