Drag Racing Tech
Wheelwell cut for 28x10.5W tire
Old 10-10-2005, 12:02 AM
  #41
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,143 Likes on 743 Posts
I have the thumb rule. If you can stick your thumb all the way around you are fine.
Mine did not rub yesterday, and I went 1.35 with them at 12 cold.
Old 10-10-2005, 02:37 AM
  #42
DMH Fabrication's Avatar
mine had a ton of room and i can always space the wheels out some if needed. When i clearanced everything, I had prokit springs w/o the isolaters so it should be good to go for any spring(most likely running stock v8 springs at the track).
Old 10-10-2005, 05:04 AM
  #43
stevemilz's Avatar
I cut and beat my Formula for my W's to fit.
Old 03-03-2006, 12:29 AM
  #44
LS1TECH Sponsor
BAGN's Avatar
"CUT & BEAT" is a understatement!
Quick Reply: Wheelwell cut for 28x10.5W tire
