Single digit guys, what wheel/tire combo do you have?
Please list:
Brand of wheel
Brand of tire
Size of wheel
Size of tire
Any fitment issues/tweaks to get them to fit (grind calipers or spacers etc)
Cost
thanks
-Steve
Brand of wheel
Brand of tire
Size of wheel
Size of tire
Cost
thanks
-Steve
I ruin the end of films...
Originally Posted by v8maro
Please list:
Brand of wheel
Brand of tire
Size of wheel
Size of tire
Cost
thanks
-Steve
Brand of wheel
Brand of tire
Size of wheel
Size of tire
Cost
thanks
-Steve
M/T ET Fronts 26" on front
M/T ET Drag, 28x10.5W on rear
Oh god yes, lots of cutting, grinding and welding to get everything to fit right.
1 Post
Bogart D10s
Moser 12 Bolt (Stock size/axle length) with 4.56 gears
I run any of the following rear tires:
Good Year 30x10.5x15
Mickey Thomspn 29.5x10.5x15
Hoosier 30x10.5x15
I have Hoosiers on the car right now, I am liking them the best so far.
I trimming the rear wheel well fender about 1" to clear the 30" tires, also removed the bump stop and beat the hell out of the frame in the wheel well with a BFH. I plan to do some mini tubbing later this year and try to tuck a little tire.
Here's a pic from a camera phone:
Hoosier 30x10.5x15
![](http://www.cancreations.com/lee/burn1.jpg)
Since Lee went ahead and put up a pic
![](http://www.quarter-mile.net/TA/images/exterior/hood02.gif)
I'm going to try to fit a 325 (#3757) drag radial under the car too this year. That should be an adventure.
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![Icon Lol](https://ls1tech.com/forums/images/smilies2/icon_lol.gif)
Here is a few pics of mine. I cut the intire inner wheel well out. The tire is a 28x10.5w on a 15x10 with 5in. back spacing. The axle was not in for the pics, but it is narrowed 3 inches per side. It is obviously not done yet, but it might have a shot at single digit's
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
So did all of you mini-tub it? Got pics of where to cut? What did you use to re-make the well? Greg, maybe I can swing by and see it?
Also, do all of you have narrowed 9" / 12 bolt rears?
Well the car isnt finished yet, but it should run single digits
Front:
Weld Aluma Stars 1 Piece 15x3.5 1.75 BS
Moroso DS2 26x4.5x15 Front Tires (Front rims and tires weigh 19lbs a piece)
Rear:
Weld Aluma Star 15x10 5 BS
Goodyear 30x10.5x15 (Rear rims and tires weigh 28lbs a piece)
Rear has been narrowed 3" per side, and car is Minitubed
Front:
Rear:
So if I get a stock length 9" rear what is the largest size tire I can put on there without mini-tub and what needs to be cut?
If I get a narrowed 9" (3"/side) what's the largest tire I can fit and I know it will need to be mini-tubed.
thanks for the help guys
-Steve
-Steve
-Steve
-Steve
Thanks!
For a 29W, I would say a minitub would be in order. For my 28W, just a lot of cutting, but no tub. I did cut out a LOT of metal, but it was all around the frame rail/spring pocket.
