Big (28"-30") tire people, please post pics of your.....
Big (28"-30") tire people, please post pics of your wheel and tire combo, also please include pics or description of body mods necessary to accomodate them.
Please include:
Wheel Width in inches:
Back Spacing:
Tire Size:
Rearend width (if not stock):
Body Modifications:
Best 60ft:
Best 1/4 ET and MPH:
Please include:
Back Spacing:
Tire Size:
Body Modifications:
Best 60ft:
LS1Tech Sponsor
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
10" magnum drags
6" backspace
295/65-15 or 315/60-15 (30" diameter)
rearend narrowed 5"
minitubbed, fenders cut back a couple inches
2-1/2" x 10" carerra springs (150# rate)
6" backspace
rearend narrowed 5"
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
2016 Z07 Carbon
LS1Tech Co-Founder
In those pics you took of my car Shawn, I am:
Wheel Width in inches: 15x10 Pro Star
Back Spacing: 7.5, no spacer
Tire Size: 28x10.5x15 ET Drag
Rearend width (if not stock): stock
Body Modifications: BFH'd some of the fenderwell up top, deburred lip, some cutting of rear bumper cover... car is around stock right height with 9", but by removing spring cups and running cut-down coil springs.
Best 60ft:
Best 60ft:
2000 -- QA1's all four corners. QA1 drag springs in front; cut stock 98 SS springs in back. We had to jack the rear-end up about 1" to make sure the tires cleared the rear fender wells. The car should be track bound for the 1st time this year this weekend.
David
Best 60' and 1/4 todate are in my signature. We'll see what this summer brings -- still totally untouched stock bottom end
I guess we'll see if it will hold a 250 shot this summer.
David
![Devil](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_devil.gif)
7 Second Club
Location: Gainesville, Florida # of drag strips runs: ?!?!?
1 Post
![Offtopic](https://ls1tech.com/forums/images/smilies3/offtopic.gif)
I'm smelling a new record, or scattered bottom-end.
Any bets on either
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Okay, back to it.....
1 Post
Don't have any pics at the moment, but:
28x11.5x15 Hoosier QTP's on
15x10 Weld draglites w/ 7.5 bs, no spacer
had to cut a little off the back wheelwell opening (plastic), remove the bumpstops, and hammer the inner fender a little.
28x12.50x15" ET Streets on 10x15" 7.5" BS'd Bogart bolted RT's.
Stock ride height(sort of)w/Moser 12 bolt(stock length axles).
Rear bumper cover plastic trimmed, slight rolling of fender lips, BFH to inside(front)well.
Spring cups removed.... no scuffing if alert
Have no pics worth posting.....
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
Originally Posted by WhtLT1
So does anyone put a 30 inch tire on a stock length rearend and 7.5 backspacing? It doesnt seem like anyone does. and if not y?
This is what I run. 29.5/10.5/15 ET Drag.
Stock width 9in
Had to cut the front and rear fenders. Roll the inside lip. BFH the inner fenders alittle. NO MINITUBS
Best of a 1.30 60ft.
![](http://www.lifeinwidescreen.com/siihp/IMG_3235.JPGtire.jpg)
Race your car!
Has anyone tried to fit the 28 inch tall e.t radial on standard bogart f body sized rims (15 x 9.75, or whatever they are) and if so, did you have any problems with the tires hitting? Being a radial.... they shouldnt' grow like a bias ply slick... must be someone that has run those by now.
Stock width 9in
![](http://www.lifeinwidescreen.com/siihp/IMG_3231.JPG)
![](http://www.lifeinwidescreen.com/siihp/IMG_3232.JPG)
![](http://www.lifeinwidescreen.com/siihp/IMG_3233.JPG)
![](http://www.lifeinwidescreen.com/siihp/IMG_3234.JPG)
Stock width 9in
Sorry to be a thread digger, but could u highlight or w/e where you ended up cutting? that size tire is too much for me but i would like to clerance for it, so I know I can fit it later on if I need it.
