Drag Racing Tech
HVAC plate
Old May 10, 2005 | 10:40 PM
moderate Z28's Avatar
Default HVAC plate
Did you guys bolt your block off plates from the inside of the firewall or the outside? Any tips on making one? Where can I get some metal and what kind is best? Thanks, its a 94 Z28.
Old May 11, 2005 | 11:37 AM
mongse's Avatar
I ruin the end of films...
Any regular tin will work. I used sheetmetal on mine. Made a cardboard template first, then cut the plate out. I fit it over the stock bolts/studs as much as I could, then RTV'd it in place. I just went back in and resealed it last month from the inside and it looks like it hadn't leaked yet.
Old May 11, 2005 | 11:49 AM
Vents's Avatar
i just used galvanized sheet metal. cut out a pattern w/ cardboard, and x-fer that over to the metal. mounted mine on the inside.
Old May 11, 2005 | 01:06 PM
bad2000ss's Avatar
I bought mine from Billingsley. Was a very good fit.
Old May 11, 2005 | 02:34 PM
SUX2BU's Avatar
made mine out of some thin aluminum i had layin around. and boled it from the inside.
Old May 11, 2005 | 06:06 PM
tektrans's Avatar
Galvanized sheet metal and I used some silicone to make it water proof.
Old May 11, 2005 | 08:00 PM
So did everyone mount the plate on the inside if the firewall? Anybody mount theres on the outside?
Old May 11, 2005 | 11:11 PM
bad2000ss's Avatar
On the inside. Sorry 'bout that, forgot to mention in the first post.
Old May 12, 2005 | 04:59 PM
SilverGhost's Avatar
Motorboater
made it out of tin or somethign a few years ago. mounted on the inside. siliconed and then used rivit gun to put it in.
Old May 13, 2005 | 01:20 AM
Mr Powell's Avatar
old Stop sign... Just measured and made a weird rectangle
Old May 14, 2005 | 04:02 AM
red90cobra's Avatar
I believe everyone including me mounted it from the inside cause it was easier to get to.
Old Aug 22, 2005 | 11:39 AM
1_Bad_LS1's Avatar
So if you just use a thin sheet of aluminum that will pass NHRA and IHRA tech? Or is there a certain thickness or type of material that has to be used?
Old Aug 22, 2005 | 12:22 PM
Ru2slo_99's Avatar
I used a scrap peice of stainless steel from the metal fabricators in my town. I paid like $5 for it. I made a template with paper (cardboard would have been easier) for the outside of the firewall. I used the bolt holes on the outside of the HVAC and siliconed in the ridge. My cover fits good and since I painted it black, it is not very noticeable.
Old Aug 22, 2005 | 10:38 PM
TimbrSS's Avatar
1 Bad LS1:
Originally Posted by S_J_H
Unless there is some other rule I don't know about, .032" aluminum or .024" steel is all that is needed for the firewall.
7.5 FIREWALLS
Each car in competition must be equipped with a minimum .032-inch (.8 mm) aluminum or .024-inch (.6 mm) steel firewall, extending from side to side of the body and from the top of the engine compartment's upper seal (hood, cowl, or deck) to the bottom of the floor and/or bellypan. Firewall must provide a bulkhead between the engine and/or fuel tank and driver compartment. In certain instances fiberglass, carbon fiber or other composites may be used. See Class requirements or consult FIA. Use of magnesium prohibited.
I used a piece of 22 guage steel sheet for mine.
Old Aug 23, 2005 | 08:17 AM
1_Bad_LS1's Avatar
Originally Posted by TimbrSS
1 Bad LS1:
Thanks alot guys...
Old Aug 23, 2005 | 05:13 PM
Little G's Avatar
Has anyone done a plate that blocks off the ac box and not the heat? My AC is gone, but I don't want to get rid of heat as well.
g
Old Aug 23, 2005 | 07:13 PM
jswhite's Avatar
To be IHRA legal steel has to be .024 thickness and aluminum has to be .032.
Old Aug 23, 2005 | 10:41 PM
TimbrSS's Avatar
g
I was going to do this, but then decided i didn't need a heater.
Removed dash.
I took the box that had the evaporator in it and cut off everything that sticks trough the firewall, except for the part part that the lines to the heater core go to.
After you get that far, you'll see what you need to do. Basically just make the normal block off plate that everyone else does, but you'll need make a provision for air from the blower motor to go through the firewall, and then back into cabin area. Sounds complicated, but you can just cut a 3 x 5in hole in the block off plate, and then weld a 3 x 5 x 1in box that size over the hole.
