Drag Racing Tech
Lightest a F-body could be?
Old May 24, 2005 | 10:11 AM
Mr Powell's Avatar
Default Lightest a F-body could be?
What do you all think a F-body could weight if it had EVERYTHING done to it, but still a stock frame. I'm talking Strang Brakes, VFN One Peice Front End, Hood, Aftermarket Hatch, Speedglass, etc, etc.....
What do you all think? ~2700lbs or even lighter?
Old May 24, 2005 | 10:16 AM
Slow Z28's Avatar
i thought Magnus was under 2700lbs w/o him in it. still stock front end pieces, only 'glass hood?
Old May 24, 2005 | 10:17 AM
mongse's Avatar
I ruin the end of films...
Does it have to be NHRA legal? I would say 2600-2700#, but we're talking a sheetmetal dash, carbon seat and no rollbars.
Old May 24, 2005 | 11:37 AM
Little G's Avatar
I think you could get it down to about 2300-2400 max
Old May 24, 2005 | 12:39 PM
TApimp's Avatar
i think 2500 pounds is acheivable. what u got in mind powell?
Old May 24, 2005 | 12:45 PM
DopeFedZ's Avatar
Is that VFN one piece front end extended? If so
Old May 24, 2005 | 01:05 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Magnus' car is in the 2660 range, no driver. He has stock rear hatch, all glass, and a suncoast hood.
I think 2500 even is doable.
Old May 24, 2005 | 01:17 PM
The Juggernaut's Avatar
Gutted, no cage, 2400-2450 is possible (no driver)
Old May 24, 2005 | 02:02 PM
Reckless's Avatar
Super Moderator
I say no way 2500 can be done
Old May 24, 2005 | 02:16 PM
LS1Tech Co-Founder
Using Keith's car, I think:
2660
-30 for pinon hood
-30 for hatch
That's with a 8 pt moly roll bar.
Keith does have wiring out of the car and stuff like that.
I think 2550 he can do, and 2500 would be hard but doable, with his cage.
Old May 24, 2005 | 02:22 PM
gator's 99TA's Avatar
remember that magazine article where they pulled off all the metal off a caddy? and then 20 years later they did it to an import of some type?
if you need a car that is 2500 lbs, why not just go with a prostock type car? even a backhalfed sheetmetal floor car is gonna be easier, cheaper, and look better IMO.
Old May 24, 2005 | 03:20 PM
10.5 Dave's Avatar
7 Second Club
From: Grove City Ohio/Port Washington L.I sometimes
I haven't weighed my car yet but I'm shooting for a 3000lb or less race weight with my new combo.
It's gutted out right now,without engine or tranny and a skinny 16 yr old boy and myself can pick up each end of the car off the ground easily.
Old May 24, 2005 | 03:34 PM
DopeFedZ's Avatar
Ok Im at 2980. I can still do a pin on hatch, lexan, brakes, manual rack and maybe a smaller aluminum fuel tank. How in the hell do you get your car in the 2600-2700 range? I have door panels, dash, carpet, two Kirkeys and a 10 point chromoly cage. Other than that everything I can think of I have taken out. My front end is mild steel should I switch to chromoly instead?
Old May 24, 2005 | 03:43 PM
93LS1RX7's Avatar
You must be one strong *** mother to lift what is still 2000 lbs of car!!
Hell if you two can lift 1000lb of car I am damn impressed.
We arent just talking about unloading the shocks? You mean "off the ground"!! wow
Old May 24, 2005 | 03:55 PM
RyanJ's Avatar
SSU Moderator
Last pics I saw of Dave's car, there was NOTHING but a cage and a body. No wires, accessories, suspension, etc. There's probably more there, but he may mean two on one side and lifting one end off the ground.
Old May 24, 2005 | 03:59 PM
Slow Z28's Avatar
My buddy and I picked up a gutted '87 Monte Carlo SS T-top car body off it's frame and we are both 6'2"-6'4" 175lb guys. when it's gutted, these things aren't that heavy, haha
Old May 24, 2005 | 04:36 PM
SMOKIN01TA's Avatar
im at 2975 with me now, im 160lbs
so thats 2815lbs right now without me
things still to do
pin on hatch with speedglass -50+lbs on a ta hatch
abs stuff under hood 10lbs
coolant tank gone for a catch can is a good 10lbs just in fluid
vfn dash would lose me another 7lbs or so
bogarts probably another 5-6lbs over my prostars
front head lights, close to 10lbs each
chromoly suspension stuff instead of steel is probably worth 20+lbs total
a manual rack
remove the alternator if you run a rear battery drag only car with charge terminals
go to a solid roof instead of t-tops 40lbs or so
gundriled axles, few lbs
lighter tranny
no brake booster
speed glass all around
i can get my car to the low 2600 range, this is in a ta with the t-tops still.
i would try it if there was a class that didnt have a weight requirement, i think there is as much skill in massive weight reduction as there is in getting the few extra hp to make up for the extra weight.
Old May 24, 2005 | 05:09 PM
NO CATZZ's Avatar
That is being very optimistic. Closer to 3lbs each is my estimate...10lbs of plastic is a LOT of plastic!
Old May 24, 2005 | 06:23 PM
Magnus's Avatar
LS1TECH Sponsor
I could get my car in the 25xx range with a hatch and front windshield using speedglass, a race seat, a pin on hood. that would easily put it in the 25xx range..
Old May 24, 2005 | 06:25 PM
SMOKIN01TA's Avatar
who said it was all plastic
