anyone running without tubes in their slicks???
anyone running without tubes in their slicks??? can it be done with hoosiers that are 28x10x16????...........i do know of a guy that has run without tubes in his slicks how safe is it
Originally Posted by MADMAN
We never run tubes. I dont like the rotational weight. Plus if you have alot of hp the tire shake is worse. Just coat the inside of the slicks with dish soap, screw the rims and go race.
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Restricted User
Never tubed, but waiting get tubbed!
As for studs, techs should follow the NHRA Ruling on them, where the stud must protrude into the lug not less then the diameter of the stud...or something like that. Basically I've run a 16" ET Street on stock rims and studs for long time. But, once I got the 15" I swapped in a set of Lingenfelter Studs, which 7 snapped within a month. Then went and found the 3" ARP's.
