Decided to mini-tub the car for the 29.5x10.5 ET Drags.
Well after much research and help from members here on the board, I decided to go ahead and mini-tub. Better safe than sorry. Plus, if the tires end up not fitting, then that will set me back even further. I'm so ready to finish this car and go race. I hope to be out on Friday. Anyhow, this job isn't so bad, just a little time consuming. Think god for a Sawzall. I had to remove the arm rest brackets in the backseat before I got started and that was a bit involved because there's tons of spot welds. Anyhow, I know it was a bit difficult for me to understand the pics I found researching this section because they were only pics of finished jobs. So I want to share the pics I have and hopefully it will do someone good in the future.
Well, went to go snap the pics and the lighting isnt that great, so I'll have pics for you guys tomorrow.
Retired Street Racer
Originally Posted by Dragaholic
Won't happen with a stock bottom end motor. The only thing I've touched was the rod bolts. Threw a set of Katechs in it. Where did you get number 7400 from?
