Drag Racing Tech
plates for a/c and radio
Old Nov 26, 2005 | 12:38 AM
1999TransamWs6's Avatar
Default plates for a/c and radio
Ive seen alot of cars with plates were the radio/A/C controls used to be and was wondering where everyone gets them from?
Thanks,
Joe
Old Nov 26, 2005 | 05:35 AM
fastlt1's Avatar
I've thought about doing the same thing. CD player don't work anyways.
Old Nov 26, 2005 | 09:46 AM
Shon Herron's Avatar
I made mine from a 'CarMax' plastic tag that comes on the front of the cars they sale. I used some black RTV and it works but I need to find a better idea. OH and I painted it black....
Some other guys are using some ABS plastic but not sure how they are attaching it and it staying, that is my concern.
Others have used some sort of sheet metal or the like....and again, not sure how they are attaching it and it staying there with switches/etc.
Old Nov 26, 2005 | 11:11 AM
yea i had bent up a piece of aluminum and bolted it right in place but it was flmzy and everytime i would hit a switch it felt like it was going to cave in. So i think im going to take some think plastic or whatever and try to figure something out.
Old Nov 26, 2005 | 12:06 PM
zeeya's Avatar
I got a peice of plexi glass. Real easy to cut. And then I took a peice of carbon fiber vinyl.(I cut vinyl) And cover it. I have my switches and a fuel pressure gauge in there.
Old Nov 26, 2005 | 01:26 PM
GM Muscle's Avatar
Here's where I got mine. http://www.partsexpress.com/pe/showd...number=265-940 . They make a few different thickness' and it matches teh factory stuff pretty good.
Here's what it looks like.
Old Nov 26, 2005 | 02:17 PM
trax's Avatar
I did the partsexpress option as well... Fits really well and looks very clean. The black blends almost perfectly with the LT1 dash.
Old Nov 26, 2005 | 02:20 PM
how did you guys affix it to the factory part?
Old Nov 26, 2005 | 02:27 PM
trax's Avatar
For the HVAC part, I took the components out of the factory switch panel, removed the vinyl "screen" that has the printing on it, and hot glued the plate to that.
For the radio... well, my head unit got stolen, so I used the flat mounting bracket and hot glued the plate to that.
I think my plate was 1/8" thick. It fits nicely, with no stretching to get the dash components to bolt back together.
Old Nov 26, 2005 | 02:42 PM
Cheater's Avatar
damn you guys dash look good
Old Nov 26, 2005 | 03:39 PM
GM Muscle's Avatar
A little super glue works wonders.
Old Nov 26, 2005 | 05:10 PM
Thanks alot guys ill be buying some soon
Old Nov 28, 2005 | 07:29 AM
1_Bad_LS1's Avatar
I just used a sheet of aluminum, punched holes for the switches with a drill press... Painted it and then used a circular wooden spacer about 1/2" thick and used the factory hardware...
Old Nov 28, 2005 | 08:22 AM
mongse's Avatar
I ruin the end of films...
Made mine from 1/8" aluminum plate.
Old Nov 28, 2005 | 08:09 PM
Cursed1's Avatar
vette=lack of penis
I also made mine out of 1/8" aluminum also. Plenty strong.
Old Nov 28, 2005 | 10:01 PM
next's Avatar
Took the idea from GM Muscle and used the partsexpress ABS plastic -
Old Nov 28, 2005 | 11:53 PM
SUX2BU's Avatar
i made a few sets out of 1/8" aluminum also. pretty easy.
Old Nov 30, 2005 | 11:35 PM
Thanks again guys I ordered the stuff that GM Muscle and next used and ill see how it works. It was cheap so if I go wrong it cheap to redo.
Joe
