Drag Racing Tech
Write up for !washer fluid?
Old Jul 10, 2006 | 12:04 PM
you2slo's Avatar
Default Write up for !washer fluid?
Is there a writeup for removing the windshield washer resevior? It's been empty since I bought the car a few months ago so I might as well save the weight. Do I have to remove the bumper cover and foam? I still have the stock SS hood and AC.
Old Jul 10, 2006 | 12:13 PM
a98ws6's Avatar
I just had to remove my bracket to where the hood latches. Then I unbolted it and it came right out.
Old Jul 10, 2006 | 12:39 PM
you2slo's Avatar
Thanks. I'll check it out tonight.
Old Jul 10, 2006 | 02:44 PM
ApacheDrill's Avatar
Yeah it just pulls through the top, you wont need to pull the bumper and mess with all that..
Old Jul 10, 2006 | 03:09 PM
you2slo's Avatar
Thank goodness. I want to lose weight, but I don't want to work too hard to do it. Just like real life.
Old Jul 12, 2006 | 10:47 AM
outkast6991's Avatar
mine came out through the bottom.all i did was remove the 3 plastic retainers that hold the bumper cover,the plastic piece that direct air to the radiator and it fell right out the bottom
Old Jul 12, 2006 | 08:27 PM
FloydSummerOf68's Avatar
I pulled mine from the bottom as well.
Old Jul 12, 2006 | 09:36 PM
partyhardoo69's Avatar
I pulled mine today. I have no bumper supports up front though. It pretty much popped right out. I also took the plastic panels behind it. Now the air will hit the radiator directly. Felt faster (air goes straight into the intake now). But I’m sure my mind is just playing games with me
Old Jul 16, 2006 | 03:09 PM
mthegodfather's Avatar
I will be removing mine soon enough.
Old Jul 20, 2006 | 09:05 AM
you2slo's Avatar
I undid the 3 clips at the bottom of the facia. I then took out the 4 clips holding in the bottle. I unplugged the pump. Got underneath and pulled it down through. Took ~5 minutes. Only save a couple of pounds since it was already empty.
