Drag Racing Tech
What size slicks?
Old Dec 18, 2006 | 11:06 PM
sykotic's Avatar
Default What size slicks?
I have a cam only car with 4.11 gears in my 9". What height slicks should I be looking for? 26? 28? something else?
Old Dec 18, 2006 | 11:21 PM
ls1408cp's Avatar
28inch
Old Dec 19, 2006 | 06:24 AM
tektrans's Avatar
If it wasn't an m6 I'd say 26" but since you're an m6 I'd go with a 28" and 4:56 gears.
Old Dec 19, 2006 | 07:05 AM
gator's 99TA's Avatar
if you make 406/374 i would run a 26" et drag. a 28" will bog the motor down with that torque and gear.
Old Dec 19, 2006 | 09:41 AM
sykotic's Avatar
ET Drag? Not a full on slick? I already have the 4.11 gears so swapping to 4.56's isnt an option, plus this is my daily driver I put about 300 miles on this car a week. Once I replace the torque arm and driveshaft at the first of the year I am planning on launching right at 6000-6200rpm, I definately need something that will hook.
My main concern here is I don't want to run out of gear at the end of the track and have to shift to 5th(or stay in 4th and slap the rev limiter). I also don't want to bog off the line but I was hoping with the new power I wouldn't have to worry. Now let me ask you this, will I need a different size slick once I slap my heads & fast 90/90 on? I'll be aiming for roughly 450rwhp and I'm guessing 410-420rwtq.
Old Dec 19, 2006 | 10:12 AM
tim99ws6's Avatar
ET drag is a "full-on" slick
Old Dec 19, 2006 | 06:09 PM
tektrans's Avatar
450 rwhp will need a 28" tire, imo. I think the 4:11's were a mistake on an M6 car with no nitrous. I think Hoosier makes a 27" slick. You may want to try that route.
Old Dec 19, 2006 | 08:03 PM
mike c.'s Avatar
all you need is a 26'' slick. i have a m6 w/4.11's(463hp) and i run m&h racemaster cheeter slicks. www.intercotire.com i cut 1.42 best 60 foot and 1.44 all day on motor. 28'' tire is too much for you at this point. i can also daily drive my 3,700lbs car if i choose too. goodluck bro.
Old Dec 19, 2006 | 08:51 PM
SlickVert's Avatar
For a M6 with 4.11 gears go with a 26 MT ET Drag
for the best M6 combo, you will need a set of 4.56 and then use an MT ET 28x10.5S(S is for Stiff side wall)
Bob
Old Dec 20, 2006 | 03:59 AM
tektrans's Avatar
Impressive 60's on that combo. You got that thing dialed in nice.
Old Dec 20, 2006 | 02:31 PM
mike c.'s Avatar
thanks. it has alot to do with the tires. the m&h racemaster out hooks EVERYTHING i've tried. m/t's hoosier,goodyear,the m&h killed them on my car. because i have no rollcage i did'nt even get time to dial it in,i got booted after two runs. i need to be more careful next year so i get more time to see what it will do.
Old Dec 20, 2006 | 02:32 PM
mike c.'s Avatar
thanks. it has alot to do with the tires. the m&h racemaster out hooks EVERYTHING i've tried. m/t's hoosier,goodyear,the m&h killed them on my car. everyone is so up to say the e.t drag is the way to go,but for me they were junk. i have no rollcage so i did'nt even get time to dial it in,i got booted after two runs. i need to be more careful next year so i get more time to see what it will do.
Old Dec 20, 2006 | 04:44 PM
chris93266's Avatar
26" unless you plan on going faster than 122 or so. at 123mph you will be at 6500 rpms. i don't know where you limiter is set, but that gives you a rough idea.
you also need to give a little of space for slippage. your car isn't dead locked to go as fast as your motor is spinning, there is always slippage ie tires... clutch...
Old Dec 20, 2006 | 05:36 PM
Kent1's Avatar
A MT or Hoosier 26.10.15 slick would most likely serve your needs. I personally run a Hoosier 26.9.15 slick in an auto-see times in sig. for a bolton car. I prefer the lightest tire possible-less rotational weight.
