10pt Roll Cage
Once installed, the areas at the welds are finished w/ a small touchup gun, and some careful masking....
FWIW,
I use thin, bubblewrap to protect the finish, while doing the install.
If you're a smaller person ( say under 6 feet, under 200 lbs ) a wolfe will probably be perfectly fine, but if you're like me ( 6'3, 275 ) you will probably be better off having a local fab guy do it for you.
It all depends on your definition of good. Some people might say the fitmant sucks because they had to work a little hard at getting the pannels to fit. I know a local guy that just bought a car and the guy that made the cage must have been a money and forgot that after the cage was welded in that he would not be able to get the interior in. Now the guy has a Z with a cage and NO plastic because there is like a 1/4 inch or less between the bars and body.
If you are interested in buying mine PM me, I am only wanting to sell it because of my size like stated above.
I think shipped to me from Dallas to a buisness address in Indianapolis was $125. He aslo shipped the plates to me and those things have to weigh at least twenty pounds or so. So I could ditch those to save on shipping and the person that installs them could just cut some steel plates up real quick to weld the cage to.
