Drag Racing Tech
Prostar backspacing - question
Old Mar 16, 2007 | 09:29 PM
WS6.Jay's Avatar
Default Prostar backspacing - question
I have some 15x10 5.5" BS Prostars. I know for 15x10 the usual is to go 7.5" BS. Besides the wheels sticking out more on the 5.5" BS, whats the difference? I'm trying to figure out if I can run the 5.5" BS ones or not. I am about stock ride height. Would there be any difference in how much the calipers need to be grinded down? I have already ground mine down some and there is a lot left to go for it to clear, we stuck in 1/2" worth of wheel spacers and it barely clears with it already ground down alot. I am not gonna run wheel spacers in the rear but that's a lot of material to cut out. Anyone got pictures of how much it took you?
Old Mar 17, 2007 | 10:22 AM
WS6.Jay's Avatar
help? can i make my 5.5" BS work with stock ride height?
Old Mar 17, 2007 | 10:44 AM
gator's 99TA's Avatar
it will look horrid. if you run a 28" tire you will most likely cut the tire on the lip of the 1/4 panel.
dont run a 1/2" spacer. grind more or buy race brakes. just buy the right sized wheel and it will save you a lot of headaches
Old Mar 17, 2007 | 10:57 AM
fastgm_silver02ws6's Avatar
i am about to grind my calipers today. and am going to take pics. i too have the same size and backspacing as u do. but i think i have a bigger tire. 325x50x15. anyway i will post pics of the entire process in a matter of hours.
other than sticking out a little more u should be fine with the backspacing.
Old Mar 17, 2007 | 11:17 AM
WS6.Jay's Avatar
Awesome fastgm, if you can get some pictures from the rear and side showing how much they stick out that'd be awesome. I have 4.11 gears so I won't be running a 28" tire, it'll be a 26".
Old Mar 17, 2007 | 12:03 PM
TS6's Avatar
TS6
While it will technically bolt on, its going to look HORRIBLE. Also isn't there some NHRA rules regarding how far a wheel can stick out?
Old Mar 17, 2007 | 12:29 PM
WS6.Jay's Avatar
I'm pretty sure he's only doing it for track use, like me. I don't go to a track enforces that NHRA ruling anyway. I could care less how much it sticks out, we had it on there and it doesn't look bad, actually looks kinda cool cause it looks like I have HUGE *** tires.
Old Mar 17, 2007 | 12:35 PM
TS6's Avatar
TS6
Post pics. I've seen guys use the 6.5 BS 15X10 and it looks very hillbilly. I don't think even Joe Dirt himself would pimp it.
Old Mar 17, 2007 | 12:58 PM
WS6.Jay's Avatar
LOL, well all I have right now is the previous owner of my wheels pictures of them on his camaro:
Old Mar 17, 2007 | 01:01 PM
WS6.Jay's Avatar
My TT2's stick out close to that much with the 315's out back:
Old Mar 17, 2007 | 01:54 PM
1BADAIR's Avatar
here's how much I ground off. Still have to use a thin spacer
http://motownmuscle.com/fileshare/files/15/rear.jpg
Old Mar 18, 2007 | 03:24 AM
revtime's Avatar
thats exactly how mine looked with the stock width rear.
A 28 inch tire would be too much, you will hit the fender on the top of the tire. Even rolling the lips will not help.
You need the 7.5 BS or do what some of us have done including me and shorten the rear 2.5 to 3 inches. Looks alot better as well.
Old Mar 18, 2007 | 08:46 AM
post pix of a 13" wide tire that is mounted on a wheel that sticks out too much! lol
Old Mar 19, 2007 | 04:18 AM
revtime's Avatar
That would be funny. The pic above is about as far as you wanna go without it looking like a clown car.
I thought it was cool till I saw your setup.......then it just looked wrong.
I have a shortened strange 12 bolt sitting in the garage now though.
Old Mar 19, 2007 | 03:29 PM
WS6.Jay's Avatar
Here's some pics:
https://ls1tech.com/forums/drag-racing-tech/678680-prostars-grinding-complete-process-25-pics.html
Old Mar 19, 2007 | 04:41 PM
i am not laughing at the car in particular but something about "clown car" was just funny
Old Mar 21, 2007 | 11:35 AM
Fire67's Avatar
WS6.Jay-
I can help you fix that problem, by buying your rears so you can get new ones!
Those are THE backspacing I set my rear end up for, and I could always use a spare set. PM if interested
