NHRA Rules: A Lot To Swallow?
All my requirements are in the Super Stock Class. (10.90) Also, if my Kirkey light-weight seat is about 6 inches from my roll bar but protects the back of my head because it is so tall, do I still have to weld some rigged-up metal bracket to connect the two? And how many tracks actually enforce the 95 decibel limit? I think the TA is much louder than that.
Thanks for the comments and experiences are appreciated! Stock parts- were just that. Not made for racing. Can a t56 take a 200 shot out the hole? Yes. Would you want to have your legs right next to it unprotected? Not I.
Balancer- SFI approved. 90% of all parts that spin at high rpms need to be a proven part under extreme conditions (hence SFI).
Tranny shield- Completely disagree. If you have ever witnessed the destruction of a tranny/clutch its not pretty. When it breaks, fragments of the clutch/tranny become high speed projectiles which could easily enforce major damage to your legs. You do like walking right? Life would be very different without them. Even though the t56/TH400 are strong trannys you always side on caution.
Seat/cage requirement- Yes the seat needs to be braced to the cage. Just weld up some thick brackets.
Noise level- Don't know of any tracks here in FL enforce this rule but I do know that Englishtown does cause its close to housing.
The rules are always changing...well updates to the rules are usually done due to the season prior and incident occured which the rule didn't cover whether there was an injury or not. Again they are always gonna go with the side of caution. I do agree that it sucks spending a lot of money on parts that don't make you go faster. -Mark
What goes wrong? how do you know when something is wrong with it?
How do you check it?
We were just talking about the tranny shield:
https://ls1tech.com/forums/drag-racing-tech/678909-nhra-question.html
A car was I think coming out of the burn out and blew the trans. Fragments went thru the SFI shield and came out and hit the guy helping with the burnout and went thru his I think elbow and out his shoulder. he got hurt pretty bad but it could have been worse.
I can't imagine what it would have done with no shield could have hit some people in the audiunce and hurt them. I can't remember but I think this was a rear engine dragster so the trans was away from the driver.
But that is a scary thought. If it can go thru that shield your floorpan would be nothing to go thru.
Most flexplate failures are from the converter/crank/belhousing bolts coming loose or something being misaligned. When guys were first putting the JW bellhousings on these they didnt realize the rear cover bolts were not letting the bellhousing sit flush to the block and it was tearing up flexplates. On a TH350/400/powerglide conversion on one of these there is no reason not to check all the bolts once in a while especially if the car is street driven. A trans/flexplate shield is a last ditch effore to stop something that a lot of times could have easily been prevented to begin with so it important to keep an eye of stuff and ears open for noises that werent there before coming from the trans/flexplate area..
Just shows how much danger there is for the empoyees working the starting line. Not that it happens all the time but you just never know and it does happen. We need to check this stuff for our saftey and theirs.
Not just that but it is a good idea to have a checklist of bolts to recheck on a schedule so they are not overlooked.
Every time I check mine I find something that has found its way loose.
Also if you are hearing a noise from anywhere that you have not heard before. Its not going to fix itself and there is something wrong so its a good idea to take care of it before you run.
The balancer rule came about in the early 80s when people would beat a 20 year old stock damper on with the sledgehammer and take their small block chevy to 10,000rpm and it the rubber was so old it just fell apart and the whole thing blew apart.
Since LS1s are fairly new and the outer ring/bonding seems to do pretty well they havent blown apart yet. Even though I have seen a couple C5 damper outer rings where the belts are move forward enough to hit the rack. Since most LSI underdrive pulleys are SFI and 'legal' at least you get a little performance for the safety..
Most tracks these days dont even check for blankets and balancers anyhow. Wheel studs, driveshaft loop, catch can, secure battery, helmet and seat belt dates are about it until you get in the 9s.
All the stuff you mentioed is not that bad OR that expensive.
Man the track you guys run at must not have insurance or some thing. You race in Division Six you better have your paper work and prepare to be inspected! If you are not legal just load up and leave
every now in then they check someones car but not very often and it is usually a street car that runs 10-11 second 8th miles and they get them for something wrong with there hood pins or something like that on there honda civic.
I never seen them check race cars.
division 2 here
Now in Chicago at the NHRA tracks they looked at everything but around here you can get away with just about anything unless you do something stupid.
It all has to do with getting cars in the track, if tech is too tough most people around here will just hit the outlaw tracks..
-Mark Whats the rule on bracing the seats to the cage?
I found out last night that all cages have to have a window net regardless of how slow the car is. Thats the only SILLY rule I have found.
It's just like insurance...I hope I, nor anyone, would ever have to test out their safety equipement, but if I do, I feel much better that I have a roll cage that went beyond the rules (extra rocker and frontal bars, etc.), have a HANS device I race with (which next year, all sub 10.0 cars will need one or another SFI approved heck & neck restraint), and so on.
If I had a guarantee that I'd never cut a tire down at speed, get another car in my lane, get out of the groove, etc., I'd rip my cage out, run in shorts, heck, maybe "nekkid" to save some more weight, and not worry about it. More likely, it's my two sons and wife that have changed my perspective a bit to say the least.
I have added less than 200#'s in safety equipment (cage, helmet, trans blanket & shield, window net, driveshaft loop, etc.). I'll take a 0.2-0.25 hit in my ET. Not trying to start any arguments, just stating that, in my opinion, it was money well spent, and that, in fact, I should have gone all the way sooner than keep running so fast without all the required gear.
Safe racing and travels to all. Take care. Dave
Right now the car runs 13's...........
This year it will run A LOT faster (single digets)
Its like the guys that built thousand plus horse motors then do the suspension later.... just don't understand it...
I have done all my safety mods in between making the car faster, so I think I have given both equal attention. I sure do miss my comfortable leather seat though!!
-Mark
As for the balancer, the stock ones have been known to fail on certain cars. And any peice weighing that much coming off at 6,000 + rpms can be dangerous. My car is good to 10.0, but nobody has ever looked at anything, not even the ds loop. I have all the SFI #s written down in my book & all they ever look at is my helmet.
