Drag Racing Tech
Offset LCA's
Old 04-16-2007, 12:20 PM
Juiced's Avatar
Default Offset LCA's
Are offset LCA's required to tuck 29.5x10.5's with mini tubs?
Old 04-16-2007, 12:22 PM
gator's 99TA's Avatar
IMO its a good idea if your BS is 5.5" or better. 10.5" isnt a wide tire but i would do it just to make sure its clear
Old 04-16-2007, 03:51 PM
jshiver's Avatar
ABSOLUTELY....Mine will not fit without the offset lca's
Old 04-16-2007, 03:59 PM
Tom the roofer's Avatar
No they are not. I had stock length Ford 9" rear end, 10" Weld draglites with 7.5" BS, 29.5" X 10" tires, No mini tub and no offset lca's. Ran that set up for 2 years.
Old 04-16-2007, 08:54 PM
here you go. the key is stock width rear. this is tom's car
Old 04-17-2007, 05:48 AM
Fireball's Avatar
He said to tuck...not to fit. I have offset LCAs and have them tucked in within 1/4" of the LCA. IMO if you want them inside the quarter panel, you need offset LCAs
Old 04-17-2007, 02:42 PM
AAAHHHHHHH my bad.
Old 04-17-2007, 02:51 PM
1QuickT-A's Avatar
If anybody wants to get rid of a set of offset control arms please let me know!
Old 04-17-2007, 02:52 PM
Juiced's Avatar
AAAHHHHHHH my bad.
No worries, i might not tuck them just yet..... i have to start my mini tub and decide what wheels to run first.
Old 04-18-2007, 03:42 AM
revtime's Avatar
Ah yes, offset LCAs.
Here is a pic of mine.
Old 04-18-2007, 06:44 AM
Rogue86's Avatar
Just curious... cant anyone just make their standard LCA's (assuming they have rod ends already) into 'offset' LCA's. Just cut some new spacers with once side longer than the other... Its what I plan to do anyways.
