Drag Racing Tech
Moser 9 inch tq arm bracket
Old Jun 29, 2007 | 10:04 AM
Torkman15's Avatar
10 Second Moderator
Default Moser 9 inch tq arm bracket
OK I have my 9 inch ready to bolt in but am questioning the sanity of bloting a 14 pound piece of cast iron AND the 5 pound bracket that came with the arm together to make a 20 pound piece of balast that can be simplified into one lighter/simple bracket. Who makes one or will it have to be a custom one off built and engineered totaly not feasable unit. Here is a pik of the one ton bracket Moser sent with the axle package.
Any ideas?
Old Jun 29, 2007 | 10:17 AM
MADMAN's Avatar
LS1Tech Sponsor
Use the one you have. We have tried to lighten them and Moser tried. The will fold up is they are changed.
__________________
www.madmanandcoracing.com
225-343-9029
Old Jun 29, 2007 | 10:23 AM
Brady's Avatar
LS1Tech Sponsor
http://teamprickracing.com/weakestlink/
use the one they sent, it's the best way to go.
__________________
1966 Chevy II twin turbo LS3 project
2016 Z07 Carbon
Old Jun 29, 2007 | 10:28 AM
kp's Avatar
kp
That 20lbs is in a good place, I dont think the old welded one was much lighter then the cast one. I see what you mean by trying to make it all one piece and bolt the arm directly to it but by the time you were done making one strong enough it would probably not weigh much less.
Old Jun 29, 2007 | 11:02 AM
Torkman15's Avatar
10 Second Moderator
Well that answers that question. I'm trying to break less not more. Prolly 50 years of dragracing knowhow tween just you guys so I'll go out and run it hard. Thanks, Tom
Old Jun 29, 2007 | 01:21 PM
vtec's Avatar
Resident Racing Jerk
i had to remove a ton of material to get my old welded style to clear my aluminum moser center.... a TON.
Old Jul 1, 2007 | 06:14 AM
FASTFATBOY's Avatar
You should have cut the ribs on the center section and not cut the bracket.
David
Old Jul 1, 2007 | 06:15 AM
FASTFATBOY's Avatar
David
Old Jul 1, 2007 | 12:01 PM
vtec's Avatar
David
it was mostly the main cap bolt heads that were in the way. didnt want to cut those....
this torque arm bracket is total overkill. the steel they used to make it is 1" thick.
Old Jul 1, 2007 | 01:52 PM
FASTFATBOY's Avatar
Total overkill? Did you see what Brady did to his? Brady is not the only one to do that to the older style welded bracket. I have installed 2 of my own, both times I trimmed the ribs on the center section, they made it that big for a reason. That bracket takes the whole load of making the car hook and transfers it to the rearend and tires.
To each his own I guess.
David
Old Jul 1, 2007 | 02:01 PM
vtec's Avatar
yours must be different from mine then, because i would have had to remove the entire bolt heads from the center section. trimming the ribs would not have helped me any.
i wound up grinding out material from the mount where i needed clearance. it took me a few grinding disks.
i realize it "handles the load" of upward force on the torque arm..... and if it breaks somehow ill do something different. i would really like to get rid of the mount setup and run the torque arm all the way to the rear somehow. kinda like one big oversized ladder bar.
anybody got any pics of brady's messed up mount?
