Tallest rear slick without major hacking?
LS1Tech Co-Founder
The 28x10.5 slicks fit easily on the Camaro, but it might take sense to go to a taller tire when these are done. I like MT's, but Hooser makes a 29" slick I think, are those any good?
Goodyear Eagle 28x11x15 are actually 28.9 tall. I have them on my car now, with only minor bumper cover trimming, inner wheel well hammering, and cut off bump stop mount. There mount on bogarts with a stock width rear. If the hoosier's are only 29 and not like 29.5 they should fit pretty easy. Is this for your Formula?
John, I hope I didn't come off as a smart *** or something. Just a year or so ago, BradWS6 was racing at GLD in the Summit Super Series, and put on his new taller slicks. They fit alright, and he *thought* there was enough clearance. At the big end they grew enough to contact the rear bottom of the wheel opening. He ended up taking about a 1/4" wide groove out of the slick all the way around - it could have been a dangerous situation. You know how nice Brad's car looks, and he wasn't about to start hacking on it either, so he went back to his normal size slicks. I just wanted to make sure you didn't overlook the possibility of them looking like they fit fine, and then having them make contact on the big end.
LS1Tech Co-Founder
Hehe, np. I usually go for a half inch of room. I remember having to look at this stuff on my 98 Formy, I actually burned away part of the rear bumper cover when I first went to a 28x10.5.
My 28 10.50's rub both the front and the rear bumper area. I adjusted the rear end back and the tires are just touching in the front. If I spray some paint on the front egde it will wear off the paint with the tire growth. So I would say some tires grow more then others. I have atleast 3/4 of a in ch in the front.
I had asked PPJ about this when I put them on so I will be trimming the bumper but I don't want to trim the quarter.
I have them on a 8 inch rim with a 5.5 inch back spacing. I would rather have the 15x10 but I got the rims and slicks for $200 because the guy didn't like the way they fit. I would like to think that on a 10" rim there would be less tire growth but I can't back that statement up.
Yes prostars.
Yes prostars.
Old Drag Racer
John, I'm just curious as to why you wouldn't want to try the lightweight radial Hoosier slicks in the 30 x 10.5 x 15 size. They're 29.5" tall and only weigh 23 pounds. They won't grow on the big end so clearancing for them should be easier. I want to run these on my car in the worst kind of way but had rather someone else give me a report on them first. Why don't you try them and let me know???
![Grin](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_grin.gif)
![The Jester](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_jest.gif)
No need to wait for somebodys report. They are proven winners by quite a few on here.
LS1Tech Co-Founder
Those tires are proven, I'd rather not run that big of a tire right now since I don't get excited about the clearancing. Plus I don't think the car needs a 30" tire to work.
