Drag Racing Tech
SFI 25.2 Mustang/LSx build "The Renegade"
Old 01-06-2010, 11:45 AM
  #2581
Fireball's Avatar
don't you need 2 dash gussets per side?
Old 01-06-2010, 12:53 PM
  #2582
7 Second Club
Phil99vette's Avatar
Not by the rules I read. 1 1/2" x .065 requires 1 per side. This is also how Wolfe sells their 25.2 cage kits.
Old 01-06-2010, 12:55 PM
  #2583
Fireball's Avatar
what size is your dash bar?
Old 01-06-2010, 01:00 PM
  #2584
7 Second Club
1 1/2" x .065
  #2585
Race your car!
JL ws-6's Avatar
I have a question, for you guys that are adding onto cages that are already painted: What are you doing with the paint when you repaint? Reason I ask... is I can see there being lines all over the place from the different thickness paints.... are you stripping the old paint off? hitting it with a scotchbrite disk to blend them in? Nothing at all?
Curious, becuase I see alot of people *** onto cars all the time, and this is something I've wondered about. I did it with my own car, but I used an epoxy-urethane paint that's really tough stuff... and it's thick, applied with a foam brush and it levels itself as it dries. But even with that, I found myself sanding and repainting some spots to get it to look right.
Curious as to what you guys are doing....
Old 01-06-2010, 01:47 PM
  #2586
Fireball's Avatar
sandpaper and elbow grease to level out. I use that vht chassis spray paint.
Old 01-06-2010, 02:00 PM
  #2587
Race your car!
JL ws-6's Avatar
Got ya. You think that's bad.. the epoxy urethane stuff I used clogs the paper quick.. but it does take a BEATING and doesn't chip/scratch easily. Takes a while to dry too, like a day and a half, sometimes 2 if it's cold but it does look decent, almost like powdercoat.
Next round of mods, where I have to repaint, I'm gonna try jut scotch-brite, and see how that scuffs the older paint up... I think it might work for the initial prep.
Old 01-06-2010, 02:24 PM
  #2588
7 Second Club
ty_ty13's Avatar
racecars arent saposed to be show cars... when you get a close look at some of the fastest cars in the business... most of them are nice but not super nice and clean.... the race car body/chassis is just a tool to smoke some ones ***
Old 01-06-2010, 04:32 PM
  #2589
7 Second Club
My car may not have the best finishes or be the cleanest but it gets the job done.
Old 01-06-2010, 04:57 PM
  #2590
Shawn @ VA Speed's Avatar
exactly-most of the fastest cars look the worst.
i'll take a fast rough car over a slow nice car anyday
Old 01-06-2010, 06:10 PM
  #2591
Race your car!
JL ws-6's Avatar
And on that note noone cares what a fast car looks like... thanks for reminding me of that
Old 01-07-2010, 02:23 AM
  #2592
Wnts2Go10O's Avatar
besides... paint is just extra weight
Old 01-07-2010, 05:54 AM
  #2593
Fireball's Avatar
phil...double check the spec...looks like for 1 1/2" dash bar the gussets need to be above the dash bar (per the text)
Old 01-07-2010, 06:07 AM
  #2594
LS1Tech Sponsor
MADMAN's Avatar
True except Phils dash bar doesnt interrupt the windshield bars.
__________________
www.madmanandcoracing.com
225-343-9029
Old 01-07-2010, 06:35 AM
  #2595
Fireball's Avatar
I know...but it doesn't specify any different. (these specs are written HORRIBLY)
says minimum size for uninterrupted is 1 5/8 x .083 (no gussets needed)
but can use 1 1/4 if you use 4 gussets
it said 1 1/2 is the absolute min for interrupted windshield bars that needs 2 gussets above (one on each side)
Since the spec associated the 1.5" bar with gussets above it, I personally would put the gussets above...that way there's no doubt come certification...
Old 01-07-2010, 07:37 AM
  #2596
here's the way i read it.If the dash bar does not interrupt the roof bars and is smaller than 1 5/8(1 1/4 min)that it is required to have 4-1'' gussets-2 upper and 2 lower.
The 2 gusset deal is ONLY mentioned when the roof bars are interrupted.
Old 01-07-2010, 08:39 AM
  #2597
Race your car!
JL ws-6's Avatar
I'd just put the 4 on and not take a chance.. tech inspector sees all 4 he's not even gonna look at that portion of things, with 2 there, the guy will probably start looking.
Old 01-07-2010, 09:12 AM
  #2598
7 Second Club
ty_ty13's Avatar
the guys with the fastest cars dont have time to build show cars as they usually expect to hit the wall during a season or atleast rotate them out ever 1 or 2 seasons.... aka lynch mob
Old 01-07-2010, 09:32 AM
  #2599
Fireball's Avatar
thats the problem with these specs. an interrupted windshield bar is less structurally sound than an uninterrupted one...why would 2 gussets be ok with that but need 4 when its in one piece?
Old 01-07-2010, 11:24 AM
  #2600
the problem is your trying to make sense of them instead of just reeading what they say.
you can't make sense out of what an engineer comes up with
Quick Reply: SFI 25.2 Mustang/LSx build "The Renegade"
