Drag Racing Tech
SFI 25.2 Mustang/LSx build "The Renegade"
Old 05-31-2010, 07:36 PM
  #3061
7 Second Club
Phil99vette's Avatar
Kitchen is nice. Its one thing to get the invite. When your Shawn miller, you've got your own bedroom, bathroom and kids room for when the races are at budds creek. And they are very nice rooms.
Old 05-31-2010, 08:21 PM
  #3062
4bangermustang's Avatar
Oddly enough, my name is also shawn miller. I'll be over tomorrow!
j/king.
Old 06-01-2010, 12:32 AM
  #3063
njc.corp's Avatar
Smile
Real nice- thanks a lot............................
Old 06-01-2010, 02:24 PM
  #3064
7 Second Club
Got alittle work done today. Threw in the mockup engine/rear end and started working on the new motor plates to get the driveline angles right, they are almost done. I just need to cut the old chassis mounts off and make some new ones which wont take long. I'll have the engine back in by the end of the week and try to start on the hot pipes and finish the downpipe.
Old 06-01-2010, 02:43 PM
  #3065
bdas70's Avatar
Hey Phil, did you get everything straight on the axle tubes? Found out yesterday we twisted our 35 spline Moser axles also.
Old 06-01-2010, 02:47 PM
  #3066
7 Second Club
Yea, I dont know when or how they warped but when we started the ends were in the correct position. I got new axles from Strange which are hardened throughout the axle where the moser aren't hardened after the splines are cut. I'm going to use a jig to put the new housing ends on which puts a straight bar through the spool so the bearings/ends are square to the spool. My tubes are pulled towards the rear of the car, the housing ends sit at the front of the tube kinda like a shorter wheel base.
Old 06-01-2010, 02:50 PM
  #3067
7 Second Club
If your ever on my side of the pond let me know, your always welcome.
Old 06-01-2010, 02:55 PM
  #3068
bdas70's Avatar
Yea thats one thing I need to check...Doesnt your rear also have a backbrace?
Old 06-01-2010, 03:15 PM
  #3069
7 Second Club
Yes, its got a backbrace.
Old 06-01-2010, 04:00 PM
  #3070
WKMCD's Avatar
and a neck brace.....
Old 06-01-2010, 08:10 PM
  #3071
Broke EF's Avatar
It must be getting old to need all those braces
Sean
Old 06-02-2010, 06:36 AM
  #3072
WKMCD's Avatar
Sean
Old?????
I doubt this car has 10-12 miles on it.
Old 06-03-2010, 12:54 PM
  #3073
7 Second Club
I got the motor mounts done today and changed over to 4 1/2" bolts on the front plate. Dropped the new hammer in and got the tranny bolted up. Once I get the tranny mount done I'll start on the turbo plumbing....
Old 06-03-2010, 04:36 PM
  #3074
WKMCD's Avatar
Phil, you know this is a picture crowd...
Old 06-03-2010, 05:05 PM
  #3075
7 Second Club
Coming shortly....Got tied up making a parts list of small stuff I need.
Old 06-03-2010, 07:12 PM
  #3076
7 Second Club
Engine back in for mockup of hot and cold pipes
Moved the motor plate mounts to the top side of the frame rails, I can drop the engine in complete, before I had to install the headers in the car.
Shawn gave me some 1/4" 6061 aluminum plate to make adapter plates for the -12 water pump bungs.
Custom timing pointer from Shawn and Brian *** @ Virginia speed
Intercooler back in the car, just need to finish welding the v-band on the intercooler pipes
Even though the intake is tall, it doesn't protrude much over the stock hood height.
Old 06-04-2010, 05:24 AM
  #3077
WKMCD's Avatar
Lookin' good Phil. When did you move the intercooler from the passenger footwell?
Old 06-04-2010, 07:51 AM
  #3078
7 Second Club
Last year mid season.
Old 06-04-2010, 06:32 PM
  #3079
The Guy in MY 99TA's Avatar
renegade... this is no renegade... this is a renegade!!!!
Old 06-05-2010, 04:06 PM
  #3080
Turbomike88's Avatar
Build List:
00 Mustang V6 5 speed:
Engine:
Iron Truck block 4.030
Lunati Rods
Callies 4" Crank
Mahle Boost pistons -32cc
ETP LS7 heads 72cc
GMPP LS7 Carb Intake
CR: ~8.5:1
Exhaust:
1.75" tube headers -> 2.5" crossover
5" downpipe
Turbo Setup:
Forced Inductions.com S95
Twin Tial 44mm Wastegates
Single Tial 50mm Blow off valve
4" Intake plumbing
1800hp Air to Water IC
Fuel system:
Custom tank
4 - Walbro 255 pumps on two circuits controlled by boost
160# injectors
ECU:
Big Stuff 3
- Dual Wideband
- Data logging capabilites
Front Suspension:
UPR K member
Custom UPR Control arms
UPR Castor/Camber CNC'd plates
Strange Struts
UPR Coilovers
Rear Suspension:
QA-1 Coilovers
Moser 9" narrowed 1.75"
- 3.50 prostreet gears
Wolfe Racecraft Upper/Lower control arms
Wolfe Racecraft Sway Bar
Wheels Tires:
Weld AlumaStar 15 x 3.5 with MT 26" Front runners
Weld AlumaStar 15 x 10 6" BS with MT 28" ET Drags
Cage:
10 point Wolfe RaceCraft
Pics:
Why two waste gates with only one turbo
Quick Reply: SFI 25.2 Mustang/LSx build "The Renegade"
