SFI 25.2 Mustang/LSx build "The Renegade"
#4261
You might be right but you remember the boost was down 3# last time we went out. I chalked it up to the wastegate seat, starting to wonder if there were 2 problems. That was the 1st time out with the v-bands/new piping. In the end you might be right but I am going to pull the intake pipes and IC tomorrow to give it a good once over.
#4262
But isnt their a way you could just pressure test you cold side with it all still hooked up??
From maybe just the throttle body? This way you can test all the clamps and everything?? Maybe capping off the turbo inlet and test it all the way?
#4268
LS1TECH Sponsor
Good luck tomorrow. Watching the rebuild has been painfully long...for us viewers...no doubt much longer for you. Keep her in one piece and give her hell.
__________________
95 Pontiac Formula- Stock engine with ATI Procharger, Moser 12 bolt w/4:30 gears, Rossler trans, Neil Chance 4000 stall, M/T ET streets, 10.914@ 121.90mph, 1.452 60ft. GMHTP November 2010 Feature Car. Check it out at:
https://www.motortrend.com/features/...ebird-formula/
http://www.youtube.com/watch?v=abZ1z...ature=youtu.be
#4269
Thanks guys, got the golf cart and car loaded up. Tomorrow we're heading to MIR and the track is always on kill. I've got a tune up in her that should work out to a 1.20-1.24 60' and hopefully mid 150s out the back door. Alot of the car remains unchanged, Madman has the suspension setup dialed in, the car is exactly where we want it on the scales, the motor should make more torque making it easier to get through the 60'l with less change in boost. Shawn is making the 3 hour trip up from virginia beach to handle the BS3 tuneups, I'll handle the power management, Madman is on call for the suspension, brian sanford and tony blanchard are going to help with between round maintenance. Should be a great night, we usually get 6 clean hits on a killer track.
#4271
Those damn o rings will **** you off sometimes. I had a porsche turbo s that had a boost leak from an o ring a few weeks back that would only go 12lbs. Car ran ok, but fixed the leak and car would hurt you. It would go 18lbs. Good luck to you guys. Hope you get some good testing. I know its been a long road for us just watching and can only imagine how longer it has been for you. Good luck and get us some vid's.
