SFI 25.2 Mustang/LSx build "The Renegade"
#4283
Had a rough night tonight, just a bunch of careless errors set us back.
1st hit, I forgot to turn on a piece of the power management which left the boost super soft down low. left at 4.5# of boost. super lazy boost curve. finally gets up to 24# boost about 3.2 seconds in. Runs a 5.10 @ 157.8. A/F was lean most of the run.
We added 20% fuel across the top side of the map and that was when things started to go down hill.
2nd hit, it moved maybe 12 inches and blew the tires off the boost came in fairly quick, pedaled it and the car just wouldn't recover. It hooked up for maybe 100' and it was clearly making more power with the fuel. Ran into some issues, found a loose dry sump fitting which caused oil to backup in the turbine housing and the valve cover was leaking at the front corner. We got both those fixed.
3rd hit, the car moved maybe 24" and spun the tires. The new motor is making soo much more torque isn't stupid. Pedaled it and rolled back into the gas. it went another 300' and it smoked the tires about 400' out, almost hit the wall.
The car should be able to go 160mph to the 1/8 mile @ 24# of boost once the tuneup and the little issues are cleared up. Good news, its still in one piece.
#4287
- need to pull the exhaust and clean the oil out.
- replace front main seal
- drop the oil pressure 40-50#
![Bang Head](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_banghead.gif)
- get some new longer bolts for the valve covers
- check the lash on the rockers
- loosen up the front shocks
#4296
I would say the new setup is making some serious power, probably capable of the most power ever made with a single turbo below 106mm with a LSx. If you pickup atleast 1mph / lb of boost that would be a min of 210 mph in the 1/4 on 40lbs... You will get the bugs worked out and shatter records.
