SFI 25.2 Mustang/LSx build "The Renegade"
#4444
Pulled the rear end out, got new brackets on the way to fix the alignment issue
Started tearing down the front end so I can make a new intercooler pipe and fuel tank
Going to make a new tank 3 gallons and move it to the driver side.
Gonna order a set of 500# injectors, waterman 19gpm fuel pump and some other little stuff.![Secret2](https://ls1tech.com/forums/images/smilies/LS1Tech/secret.gif)
![](http://i277.photobucket.com/albums/kk80/JessNPhil_2008/2000%20Mustang%20Drag%20Radial%20Hot%20Rod/IMG_4520.jpg)
![](http://i277.photobucket.com/albums/kk80/JessNPhil_2008/2000%20Mustang%20Drag%20Radial%20Hot%20Rod/IMG_4521.jpg)
#4458
Looking Great Phil!
You know what this means dont you?................
You get to put the passenger seat back in
How much weight do you figure you lost with all the cooling system and what not?
![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
#4460
just a suggestion, but it would strengthen up the control upper brackets, if you would weld in a gusset all the way around the axle tube end and main housing inside the diff. area
