Drag Racing Tech
SFI 25.2 Mustang/LSx build "The Renegade"
Old 03-06-2008, 05:49 PM
  #441
BigBronco's Avatar
Congrats on the new child!
Old 03-06-2008, 07:23 PM
  #442
7 Second Club
Phil99vette's Avatar
Tried to take some pics but black is hard to photograph, car looks incredible. I'm about 40% done with the buffing.
1
3
5
Old 03-06-2008, 07:35 PM
  #443
7 Second Club
Well everyone can see the paint is finally done. It took more time than we had expected but we learned alot of good things on the way. We were going to have a local shop paint it but I felt like he was trying to break the bill off in my A$$. We went back and started over with a 2 part urethane primer and finished some body work we missed. He painted it in his garage that we did our best in sealing off but there was still some crap in the paint that came out when we wet sanded it. I picked up the car today and it was sanded with 2000. I used a Cutting and Polishing Waffle pad with two different compounds. I have not done the final step but its pretty damn close. The car looks soo damn good in person its not funny. Is it perfect, nope but its pretty damn close.
Old 03-06-2008, 07:55 PM
  #444
GrahamHill's Avatar
Congrats! When the polish is layed down she'll look awesome!!
Old 03-06-2008, 09:40 PM
  #445
RAGENZ28's Avatar
Looks good to me Phil
Old 03-06-2008, 11:54 PM
  #446
JRracing's Avatar
Looks good phill. It looks like you using the polishing pad to compound with. The white pad is for compound and the black pad is for polishing. After you polish it with the black pad, buy the blue one and the blue ultra fine polish (3M) it will really bring out the shine in a black finish. I always take it one step further with black paint.
Also watch letting the compound dry on the door jambs, that stuff is hard to get off when it dries lol.
Keep up the great work!
Oh, congrats on your lil one! We just had our first, a little girl. She will be 6months on the 19th. She's the apple of my eye. And I just finished her first car. It's a antique metal pedal car I restored and painted pink lol.
Old 03-07-2008, 08:51 AM
  #447
7 Second Club
Thanks for the tips. I've been using Dupont 1500S medium cut with a medium cut white waffle pad for the first step. After that I've been using the medium cut with a gray polishing pad(fine cut). Third step I switch to 3m Finesse it finishing compound with a polishing pad.
Phil
Old 03-07-2008, 05:26 PM
  #448
7 Second Club
Stef's custom oil pan...
Old 03-07-2008, 10:41 PM
  #449
RAGENZ28's Avatar
You're so Phil
Old 03-08-2008, 11:37 AM
  #450
slammer454's Avatar
Originally Posted by RAGENZ28
You're so Phil
hey, where do you think he's gettin the money to pay for all this?
Old 03-09-2008, 01:15 PM
  #451
7 Second Club
Here is the best pic I can get of the paint....
Old 03-09-2008, 05:20 PM
  #452
JRracing's Avatar
Looks great! Don't forget, use the blue pad and ultra fine polish on the final polish. You will thank me for the tip. LOL. It takes the shine to another level.
Old 03-09-2008, 06:19 PM
  #453
ls2 bait's Avatar
engine bay shots! i wanna see it before the motor gets in the way
Old 03-09-2008, 11:03 PM
  #454
RAGENZ28's Avatar
His wife, don't they all control the money?
Old 03-11-2008, 03:27 PM
  #455
7 Second Club
I've been working as much as I can on the car and we've hit some road blocks that I hope to have resolved this week. The dry sump has been soo much of a pain its not funny.
- The pan had to be machined on a mill to clearance for ARP main studs where the windage tray bolted on.
- Starter now doesn't fit because the pan is buldged out on that side but the mount can be machined to shorten it up which *MAY* work with the pan, inital fitting showed the mount hitting the pan
- -12 fittings have a good sized radius and there is just not enough room for fittings ontop and botton of the dry sump, my dad picked up 2 - 90 degree AN to ORB fittings that we're going to try this week to clear up the clearance issue with the K-member
- Next problem is the steering rack, I forgot to check the clearance between the steering rack and the dry sump pump but we've got issues there, I'm crossing my fingers that I can roll the steering rack down 60 degrees so the output shaft that goes to the steering column. The steering rack output shaft would be flat or parallel to the ground and may need to be shortened to work, the hole in the firewall may need to be dropped an inch or 2 to get it to work.
- Still need to fabricate 2 more x-braces for the cage
Old 03-12-2008, 04:43 AM
  #456
slammer454's Avatar
Keep tryin Phil! We all know it'll be worth it in the end!
Old 03-13-2008, 01:13 AM
  #457
borninatransam's Avatar
phil with all the headaches, hang ups, and stalls in this project have you ever wished you would have went a different route? possibly just getting an fbody and doing the same thing?
Old 03-13-2008, 02:07 PM
  #458
7 Second Club
Nope because an F-body isn't a magical car where everything fits right he first time.
Old 03-13-2008, 02:18 PM
  #459
GrahamHill's Avatar
Thats the damn truth! lol
ANY generation mustang from 79-up is the ideal platform
Old 03-13-2008, 08:52 PM
  #460
7 Second Club
I've had a very tough time trying to get ample clearance on the dry sump, tried the pump in at least 8 positions. The only one that works is pulling the pump out and running it off the very forward drive. There is not enough room to run it off the back of the ATI damper, any thoughts are welcome.
Pulled pump out, way out. Moved the bracket from between the first two pumps to the 2nd/third pump. Changed from the back of the plate to the front of the plate.
had to use an assortment of fittings to change the hose height to clear
shorty hose still 4-5"
2nd section hose
3rd section hose
Last section hose
Quick Reply: SFI 25.2 Mustang/LSx build "The Renegade"
