SFI 25.2 Mustang/LSx build "The Renegade"
#4601
This is the mag drive I am going to use. It will bolt onto the front of the cam with marman clamps and the fuel pump will bolt on the backside of the mag drive. Mag drive will point up and toward the driver side at a 30 degree angle.
![](http://rcdengineering.com/files/products/Images-jpg/302500-0020-pi-72.jpg)
#4608
The only wires I have ever lengthen is the two yellow wires that go to the 8973 from the chip slot on the points box. Had no effect on operation. That brings up another question, are you going to run a 7730 or 8973 box with this setup?
#4615
not sure if anyone has told you, but with the 44 MAG, you need to spin a min. of 250 rpm on the starter for it to fire. It needs a little more with a 8973 box on it but never tried it with BS3. If you have trouble starting on starter log start rpm and see what it is. Usually have to get a high speed starter to spin the MAG fast enough.
#4618
