SFI 25.2 Mustang/LSx build "The Renegade"
#4665
Before at 4050 it would only make 5.5psi maxed out
Now at 3800 it will make 6.5psi cold, probably more on a better tuneup
@ 4000 it easily makes 9.5psi cold and again will make more
Game plan for the 1st hit, 3800 and 6.5psi, moderate boost ramp settings and 20psi out the back door. On the dyno at 15psi, plugs showed 30/40% cad burn and no timing mark.
#4669
#4672
#4675
I am going to pull it out and get the pumped checked out. Was in high gear, let off, shifted to neutral and killed it, on methanol it takes a second once its killed. Almost as soon as I killed it, the tranny started the ol leaky leaky. Dipstick showed middle fluid level but it had 6 quarts in the sumbitch.
